What can be replace the L14F1 and LD271 ?
  • Thread starter Thread starter spyerpeacer
The discussion revolves around finding alternative components to replace the L14F1 and LD271 in a specific circuit involving a power switch with an infrared proximity sensor. Participants explore potential substitutes due to difficulties in sourcing the original components.
  • One participant suggests that any LED and photo-diode or transistor could potentially work in the circuit.
  • Another participant mentions that an LED from a discarded TV remote control might be suitable and emphasizes the need for an infrared receiving photo transistor if using an infrared transmitting diode.
  • There is a query about replacing the solid state relay (S201S02) with another relay, with a response indicating that an ordinary relay could suffice for normal use, but caution is advised when switching mains voltage.
  • Participants discuss the need for a transistor to drive the relay and the importance of including a diode across the relay for protection.
  • Questions arise regarding the connections in the circuit diagram, specifically about data input and the necessity of a separate power supply for a 24VDC solenoid valve connected to the relay.
Participants express various viewpoints on suitable replacements for the components, and while some suggestions are made, there is no consensus on specific alternatives or configurations. The discussion remains unresolved regarding the best approach to take.
Participants express uncertainty about the compatibility of different components and configurations, particularly concerning the relay and solenoid valve connections. There are also unresolved questions about the specifics of the circuit diagram.
spyerpeacer
what can be replace the L14F1 and LD271...?
hai...
i would like to know what can be replace the L14F1 and LD271 in this circuit...?
http://electroschematics.com/6161/power-switch-with-infrared-proximity-sensor/"
ive difficulties to find my component in my country...
so i want to know other alternatives for the component...
thanx for ur help...!
You should be able to use just about any LED and photo-diode/transistor in that circuit. See what you can find in the junk box...
The LED from a discarded TV remote control may be OK and could be salvaged for use in projects like this.
The photo transistor will depend on what is available at your local electronics store. If you use an infra red transmitting diode, you need to use an infra red receiving photo transistor.
The exact type probably doesn't matter much.
schip666!-thanx...
vk6kro- for the solid state relay(S201S02), can i replace it with other relay...?
i also can't find the component in my area...
spyerpeacer said:
schip666!-thanx...
Yes. A solid state relay is mainly used for very long term reliability. For normal use, an ordinary relay is fine.
Just for safety, if you are switching mains voltage, get a relay that has a protective cover on it.
Also, you will need to drive the relay differently. You will probably need a transistor to drive it and a diode across the relay to protect the transistor.
like this:
You will have to arrange the relay contacts to suit your application as this circuit will turn the transistor off when the reflected signal is detected.
in the diagram u show me, i not quite understand it...
do the DATA in the diagram comes from my pin no 8 in the circuit...?
does it means like that...?
if i use solenoid valve 24VDC at the output of relay,
do i need another supply to connect to the solenoid valve...?
YES
YES
thanx a lot for ur help...
i will try it...
i really appreciate it...
  • · Replies 26 ·
  • · Replies 31 ·
