What Are the Products of Zinc Sulphate and Barium Nitrate Reaction?
  • Thread starter Thread starter jools111
    Chemical
The discussion centers on the reaction between zinc sulfate and barium nitrate, focusing on identifying the products and understanding solubility rules. Participants clarify that both reactants are soluble in aqueous solutions, leading to potential products of zinc nitrate and barium sulfate. However, barium sulfate is noted as insoluble, which would result in its precipitation. The conversation emphasizes the importance of recognizing solubility exceptions and the necessity of mixing in solution rather than as solids. Ultimately, the balanced equation for the reaction is ZnSO4(aq) + Ba(NO3)2(aq) → Zn(NO3)2(aq) + BaSO4(s).
jools111
Write and Balance equations for the following reactions:
zinc sulphate + barium nitrate ----->
I know that the formulas for the reactants are :
ZnSO4 + Ba(NO3)2 ---->
I'm just having a really hard time coming up with the product for these type of questions. I have no problems writing the formulas for the individual compounds, and balancing afterwards is good to go as well. It's the products I'm having trouble with. Can anybody give me a shove in the right direction? Thanks.
I end up with a mixture of ions initially after mixing them. But there appears to be a compound that is insoluble...
So could I use the model for an exchange reaction,
AB + CD ----> AD + CB
ZnSO4 + Ba(NO3)2 ----> Zn(NO3) + BaSO4
Does that work?
jools111 said:
Does that work?
In general - no. ZnCl2 + Ba(NO3)2 is no reaction. However, do you know solubility rules? If so, do you see potentially insoluble salt? (That's what Fightfish already signalled).
I'm not 100% on solubility rules yet... but I'm getting there. I do see that barium sulfate is insoluble. But there are no liquids in this reaction... so how does solubility come into play? Also, you have zinc chloride as the first reactant. Shouldn't it be zinc sulfate? Or have I missed something again...
The only way any reaction may happen is if you mix these salts in solution - when you mix solids, nothing happens. And zinc chloride/barium nitrate was just an example of very similar mixture which doesn't react - it just sits in the solution for ever.
So the question states:
Write and balance an equation for the following reaction
With both these compunds beings solids... I understand how there would be no reaction. Am I to assume that a liquid is added, and part of the reaction? I am really confused with this question.
Approach it as if you were mixing solutions. So not
ZnSO4 + Ba(NO3)2
but
Ok... So based on the general solubility rules, most nitrates and sufates are soluble. Which makes both of our compunds soluble... Can I not apply the exchange rule:
AB + CD ---> AD + CB
To give me:
ZnSO4 + Ba(NO3)2 ---> Zn(NO3)2 + BaSO4
Even in an aqueous state, the rule should apply right?
Most, but not all.
The rule states:
2. Most nitrates and acetates are soluble. AgC2H3O2 is moderately soluble.
4. Most sulfates are soluble except BaSO4, SrSO4, and PbSO4. CaSO4 and Hg2SO4 are moderately soluble.
If it is not part of the rule, how can I tell what is soluble and what is not?
Fourth rule specifically points to what salt will precipitate from the solution.
I'm sorry... I'm not following. In my book the fourth rule states:
Would the precipitate not be one of the products? Neither of the reactants in my equation are listed there...
Seems like you are missing something... Do you know that salts are dissociated in water? Your solution contains Ba2+, Zn2+, SO42- and NO3-. They can recombine producing 4 possible salts. Of these most are soluble, so they won't precipitate.
I am a bit confused too... As you have said, the solution contains 4 possible ions that recombine to form 4 possible salts. Since barium sulphate can be formed, why doesn't it precipitate from the reaction?
