What are the rules for initial value problems?
bbb3
Why is it that you are able to have 1 initial value problem with 2 solutions, but not 2 initial value problems with 1 solution for an ODE?
Is there a theorem that states this?
I have no idea what you are asking. What do you mean by "1 initial value problem with two solutions"? I was under the impression that an initial value problem either had a unique solution or had an infinite number of solutions. (That's basically a statement of the "Fredholm alternative"). On the other hand, as to "not 2 initial value problems with 1 solution for an ODE?", it's easy to make up two distinct intial value problems having the same solution. Is that not what you meant?
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
