@PK nd
- 25
- 2
Are we alone AND what are the ways we can search alien life?
I think if there were other intelligent life within the solar system we would have had a definite indication of some sort by now.newjerseyrunner said:... Are we likely alone? No, it's likely we're not even alone in our own solar system.
I made no specifications about the intelligence of in solar system life. No evidence is not the same as evidence of nothing. It's highly likely that we are the only intelligence species in this solar system.rootone said:I think if there were other intelligent life within the solar system we would have had a definite indication of some sort by now.
Most of the planets have surface conditions which would one way or another be lethal for carbon based life similar to that on Earth.
Only Mars could be possibly be survivable given an enclosed habitat and adequate shielding from radiation - Mars' atmosphere doesn't cut it as a radiation shield like Earth's does.
Primitive life might be possible in the subsurface water oceans of some gas giant moons, but there is no evidence at present suggesting that this is so.
I'm not sure there's any reason yet to believe that there is life beyond the Earth within our own solar system (aside from the microbes we've sent out from the Earth in our probes). There are some tantalizing possibilities of life in places like Mars, Titan, and Europa, but so far no evidence.newjerseyrunner said:I made no specifications about the intelligence of in solar system life. No evidence is not the same as evidence of nothing. It's highly likely that we are the only intelligence species in this solar system.
I don't think that's accurate. High-energy cosmic rays are not deflected at all by the Earth's magnetic field. Those tend to impact the upper atmosphere, and result in a relatively low level of high-energy radiation that we're exposed to every day. The upper atmosphere also reduces incoming ultraviolet radiation.newjerseyrunner said:Your physics is also incorrect. Earth's atmosphere has little to do with radiation. It protects against UV, but its the magnetic field that deflects the majority of dangerous particles, that's what Mars lacks. It does however have a warm interior and we know that life on Earth is perfectly happy under kilometers of rock.
"Good indicator" is a bit strong. There's a pretty wide gulf between the comparatively simple organic molecules we've detected and life.newjerseyrunner said:There is plenty of evidence of organics, Cassini flew through the jets of Enceladus and confirmed their presence, while not indicative of life, it's a pretty good first indicator. Organic molecules are also present in the surface of Europa.
I specified good FIRST indicator for that reason. I agree, them being there is not a good indicator of life, it is however a good indicator of a potentially inhabited world.Chalnoth said:"Good indicator" is a bit strong. There's a pretty wide gulf between the comparatively simple organic molecules we've detected and life.
The atmosphere is much more important in terms of shielding. Compare the radiation levels from cosmic radiation received on at sea level (shielded by atmosphere and magnetic field) with those on the ISS (shielded by the magnetic field and a thin spacecraft hull) and on the way to moon (shielded only by the spacecraft hull). Sea level to ISS is a factor of roughly 1000, while ISS to moon is a factor of about 2-3.newjerseyrunner said:Your physics is also incorrect. Earth's atmosphere has little to do with radiation. It protects against UV, but its the magnetic field that deflects the majority of dangerous particles, that's what Mars lacks. It does however have a warm interior and we know that life on Earth is perfectly happy under kilometers of rock.
Sorry, can you clarify?newjerseyrunner said:I specified good FIRST indicator for that reason. I agree, them being there is not a good indicator of life, it is however a good indicator of a potentially inhabited world.
Inhabited in the sense that there is anything at all living on it, not intelligent species. And organic molecules being a good indicator of POTENTIAL, not actually inhabited. In such a way that seeing ice caps and dark channels on the Martian landscape was a good indicator that Mars was potentially inhabited in 1900.DaveC426913 said:Sorry, can you clarify?
You seem to have said that organic molecules are a good indicator of a potentially inhabited world.
Except that they weren't a good indicator. (As on the Moon, there is also ice, but certainly no life, therefore ice is not a good indicator of life)newjerseyrunner said:In such a way that seeing ice caps and dark channels on the Martian landscape was a good indicator that Mars was potentially inhabited in 1900.
The atmosphere would protect the surface from solar wind as well, if necessary.newjerseyrunner said:Oh. The magnetic field is what protects the atmosphere from the solar wind, but the atmosphere itself is what protects the planet's surface from high energy radiation?
Again, I said nothing about indicating habitation. I only said it indicates potential. Enceladus indicates potential, Anthe doesn't. That's all I mean by indicating, the way I was using it, any object with liquid water and simple organics has potential, as well as Titan and places with potential for exotic life. I only meant to illustrate that the building blocks of known life are known to exist there. I should have been more careful with wording.@mfb, Why doesn't the solar wind rip Venus' atmosphere off? I know the composition of the atmosphere is mostly fairly heavy molecules, is Venus's gravity enough to maintain it or is there something else going on there?DaveC426913 said:Except that they weren't a good indicator. (As on the Moon, there is also ice, but certainly no life, therefore ice is not a good indicator of life)
Just like Enceladus, organics are not a good indicator of habitation.
So I'm not sure why you're saying they are.
If you figure it out completely, write a paper...newjerseyrunner said:Why doesn't the solar wind rip Venus' atmosphere off?
Organic molecules are a necessary condition for organic life, but nowhere near sufficient.newjerseyrunner said:I specified good FIRST indicator for that reason. I agree, them being there is not a good indicator of life, it is however a good indicator of a potentially inhabited world.
Chalnoth said:Organic molecules are a necessary condition for organic life, but nowhere near sufficient.
You also need some sort of out-of-equilibrium energy process to sustain any life, as well as an environment that is sufficiently gentle to prevent immediate breakdown of molecules complex enough for self replication.
I do expect that the formation of life is essentially inevitable given the right conditions, I'm just not sure those conditions existed anywhere but the Earth within our own solar system. I strongly support searches for life elsewhere in the solar system, I'm just not sure we yet have cause for optimism.
Paragraphs!ogg said:Unfortunately, many... ...the atmosphere at all.
And funilly enough I was looking for something interesting to spend a couple of hours watching while I had nothing better to do.newjerseyrunner said:Funny how often my Youtube queue has had a video about something I've seen on this forum.
If it's too long the short version is ...
Chalnoth said:"Our best bet for finding life outside of our solar system is by looking at the atmospheres of planets orbiting other stars. As far as we know, life is the only thing that can maintain an atmosphere that has out-of-equilibrium chemistry."
Depends on the power of the emitter and the distance.Monsterboy said:so according to this article the SETI can only work if an alien message is beamed directly towards earth
Depends on the intent of the emission. In ~20 years we should have the technology to discover Earth (if we wouldn't be on it) as likely candidate for life from tens of lightyears away, even without finding radio emissions. Aliens might have studied our atmosphere and considered Earth as possible place for intelligent life.Monsterboy said:that's highly highly unlikely right
Right.Monsterboy said:About that narrow band signal , it refers to the narrow band of frequencies?
It's possible that intelligent aliens could decide to send a highly directional signal to Earth if they already had a good reason to suspect there was a liklihood of the message being received.Monsterboy said:... SETI can only work if an alien message is beamed directly towards Earth , that's highly highly unlikely right ?
That's a fairly fanciful definition of intelligence, IMO. I think intelligence is, by definition, distinct from complex behavior. Bees certainly have complex behavior, but the reason they haven't contacted us is because they are not sentient.Chronos said:For example, bees behave in an organized and purposeful manner. etc
If something would have ended life on Earth 1 million years ago Earth would never have developed such a species.rootone said:Then again perhaps a technological species becomes inevitable at some point once life has evolved beyond the level of plants.
True, but life here seems to have survived near extinction several times.mfb said:If something would have ended life on Earth 1 million years ago Earth would never have developed such a species.
A billion years is oodles of time to evolve an alternate energy extraction mechanism.mfb said:And there is always the timescale. The sun becomes more luminous over time, which reduces the CO2 content of the atmosphere. At some point, it will become too low for photosynthesis. In roughly a billion years the greenhouse effect (based on water, not CO2) kills whatever remained on the surface or in the oceans.
I think bees and ants don't really think about organization, (they didn't organize themselves consciously) they are just biologically programmed to do what they are doing , that's why they can't be called intelligent and that's why there is no technological development.DaveC426913 said:That's a fairly fanciful definition of intelligence, IMO. I think intelligence is, by definition, distinct from complex behavior. Bees certainly have complex behavior, but the reason they haven't contacted us is because they are not sentient.
The main difference between the animals you mentioned in this post and humans is the way knowledge is handled , humans activity teach their young about what they already know so that their younger generation won't have to rediscover and reinvent everything again and so they can explore and acquire new knowledge,animals don't do that so every generation has to relive it's previous without any accumulation of knowledge, hence no improvement in technology.Chronos said:I would argue that technology is merely an extension of intellect. Many creatures on Earth exhibit undeniable ability to communicate or uttilize simple tools, e.g., birds, otters, chimps yet we deny they possesses sentience because their technology appears primitive and unevolving.
Hmm...looks like ants do group learning but I don't understand to what level they actually 'think' of themselves as one colony with some kind of identity.Many animals can learn behaviours by imitation, but ants may be the only group apart from mammals where interactive teaching has been observed. A knowledgeable forager of Temnothorax albipennis will lead a naive nest-mate to newly discovered food by the process of tandem running. The follower obtains knowledge through its leading tutor. The leader is acutely sensitive to the progress of the follower and slows down when the follower lags and speeds up when the follower gets too close.[92]
Controlled experiments with colonies of Cerapachys biroi suggest that an individual may choose nest roles based on her previous experience. An entire generation of identical workers was divided into two groups whose outcome in food foraging was controlled. One group was continually rewarded with prey, while it was made certain that the other failed. As a result, members of the successful group intensified their foraging attempts while the unsuccessful group ventured out fewer and fewer times. A month later, the successful foragers continued in their role while the others had moved to specialise in brood care.
Looks like my initial guess that ants don't learn from their previous generation is wrong but the reason why they didn't develop technology (another guess) is that they don't try to improvise on what they learn from others (they don't innovate) each ant just blends into a 'specialized module' and doesn't think differently.Evolution has equipped ants with a distributed system of specialised modules interacting together. These results demonstrate that the navigational intelligence of ants is not in an ability to build a unified representation of the world, but in the way different strategies cleverly interact to produce robust navigation.
We need to keep in mind that this is only our current level of understanding. Even insect brains are far too complex to be fully understood in the near future.
.The ants that nursed the queen and the young tended to be young, slightly older ants were responsible for cleaning the colony and the third group of ants, usually the oldest, foraged for food outside the colony.
*They also discovered that ants only socialise within their career groups
The six-year project by scientists at the University of Lausanne in Switzerland, accumulated the largest ever data of ant interactions.
Chronos said:The question becomes - given these obvious signs of intelligence - why have they made no apparent attempt to contact us? Perhaps they have, but, concluded our minds lack sufficient awareness to recognize their efforts, therefore we are not sentient..
I beg to disagree. Science or no, I would be extremely interested to carry on a conversation with an intelligent species. I suspect there is a large spread on the continuum of intelligence between mere "animal intelligence" and "science-capable intelligence."newjerseyrunner said:Intelligence isn't enough to be interesting, they have to have science. Intelligence and even technology can only go so far without science. Lots of creatures make tools, they can understand that something works. Only humans try to understand WHY.
Me too, but at least in the near future we won't get that chance unless they are in the solar system or have technology for interstellar communication.DaveC426913 said:I would be extremely interested to carry on a conversation with an intelligent species
Or if they have extremely good hearing.mfb said:Me too, but at least in the near future we won't get that chance unless they are in the solar system or have technology for interstellar communication.
I would suspect we are on the very very very bottom of that continuum. We just walked out of nature and started separating ourselves from it. We're just starting to look at the programming that makes us, and learning how to play with it. I would bet that most species would do this, and even with just minor tweaks here and there, over enough time, a species would be unmeasurably more intelligent. Some species will wholly embrace the new technology and greatly boost their collective intelligence for several generations. Self improving machines are a whole different can of worms.DaveC426913 said:I beg to disagree. Science or no, I would be extremely interested to carry on a conversation with an intelligent species. I suspect there is a large spread on the continuum of intelligence between mere "animal intelligence" and "science-capable intelligence."
Imagine if Dolphins were intelligent enough to share with us their views on art, philosophy, relationships, love and death.
DaveC426913 said:I would be extremely interested to carry on a conversation with an intelligent species.
Allow me to contradict with you, the bio-molecules are the first step to this study introduced by the most imaginative astronomer of the last century Dr Fred Hoyle. On the basis on his thoughts and H&W study of bacterial transportation through interstellar environment, India already launched a research program under the leadership of Dr J V Narlikar (Student of Fred Hoyle and the co-author of Hoyle-Narlikar gravitational theory)... You can go through this article...DaveC426913 said:Except that they weren't a good indicator. (As on the Moon, there is also ice, but certainly no life, therefore ice is not a good indicator of life)
Just like Enceladus, organics are not a good indicator of potential habitation.
It's quite possible that there is intelligent life in our solar system and we just don't have the capability to perceive it. If "God(s)" exists, that would be a good example. Or maybe beings made of dark matter, hive minds, etc. There are a lot of possibilities that I can imagine. I think it is a little arrogant for humans to assume that intelligent beings have to be like us or at least have technology/artifacts similar to ours.rootone said:I think if there were other intelligent life within the solar system we would have had a definite indication of some sort by now.
A minor point, but actually our atmosphere does protect us from high energy neutrons which are absorbed by nitrogen to form carbon 14. Not sure the flux is much compared to charged particles, but I would call that a form of radiation. Mars' atmosphere is mostly CO2 with little nitrogen. Anyone know what percentage of neutrons actually make it to the surface of Earth? I'm sure it's a much lower number than on Mars.newjerseyrunner said:Your physics is also incorrect. Earth's atmosphere has little to do with radiation. It protects against UV, but its the magnetic field that deflects the majority of dangerous particles, that's what Mars lacks.
