What branch of math deals with nonlinear systems?
To study nonlinear systems, one should explore fields such as nonlinear dynamics, differential equations, and possibly chaos theory, as these extend concepts from linear algebra. A foundational understanding of calculus, particularly multivariable calculus and differential equations, is beneficial before delving into these advanced topics, as many university curricula emphasize these subjects first. Abstract algebra and complex analysis are also relevant, with abstract algebra focusing on algebraic structures and complex analysis dealing with functions of complex variables. The discussion highlights the importance of recognizing different representations of equations, such as transforming inputs and outputs in various dimensions, which are both valid perspectives. Understanding these mathematical frameworks enhances the study of nonlinear systems and their complexities.
V0ODO0CH1LD
Like linear algebra goes in depth about linear systems, what should I look for to learn about the extension of linear algebra to nonlinear systems? Is there a name of the field of study? If I go into a book store to buy books about it, what should I be looking for?
Abstract Algebra? Complex Analysis? If not, what are those anyway?
Also, I've realized that is cool to know some calculus before linear algebra to relate some topics, but not necessary. Is multivariable calculus and differential equations something I should know before all of this other things? I'm just asking cause most universities have calculus up to differential equations before any of the stuff I'm asking about, including linear algebra. Is that for a particular reason?
Thanks!
Mathematics news on Phys.org
I think linear algebra occupies a unique position because even arbitrary transformations can be treated as instantaneously linear and then integrated with respect to some parameter to capture the full, nonlinear effect of the operator. So, some calculus would be helpful there.
Abstract algebra goes into stuff about rings, fields (not fields not a vector space, but fields of numbers), and other general structures which admit an algebra but may be more exotic than the algebra of real numbers. Vector spaces are a topic of study under abstract algebra, too.
Complex analysis is the study of functions of a complex-valued variable, just as real analysis is the study of functions of a real-valued variable. Complex numbers in general are just a way of talking about points or vectors on a 2d plane.
Okay, I've another question related to the subjects we are discussing, but not to my previous question.
If you look at an equation like f(x) = y = x. It has one input and one output, right?
But you can also write it like f(x, y) = 0 = x - y. In which case you have two inputs and one constant output.
In one equation I transform the 1-dimensional vector x into the vector y using the identity function. And in the other case I transform the 2-dimensional vector <x, y> into the the 1-dimensinal vector 0. So <x, y> can be any orthogonal vector to <1, -1>.
Are both ways of looking at the equation valid?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
