What causes EMF induced in Faradays law when only B changes
The discussion revolves around the origins and implications of Faraday's Law of electromagnetic induction, particularly focusing on the conditions under which electromotive force (EMF) is induced when the magnetic field (B) changes while the coil remains stationary. Participants explore theoretical foundations, empirical evidence, and the relationship between different electromagnetic laws.
  • One participant expresses difficulty in understanding the origin of Maxwell's Laws, particularly questioning how EMF is induced when only the magnetic field changes, without moving the coil.
  • Another participant suggests that Maxwell's equations are derived from empirical observations and cannot be fully deduced without experimental input.
  • There is a suggestion that Faraday's induction experiment is crucial for the formulation of Maxwell's laws, indicating a reliance on empirical discovery.
  • Some participants propose that while Maxwell's laws cannot be derived from one another, they can be derived from other foundational principles such as gauge symmetry and conservation laws.
  • A participant inquires whether Faraday's Law can be explained using more intuitive starting points like charge and mass conservation, rather than abstract concepts like gauge symmetry.
  • Another participant mentions that deriving individual Maxwell's equations from basic principles is challenging, often requiring assumptions that lead to multiple equations rather than isolating one.
  • There is a hypothetical discussion about how the formulation of Faraday's Law could change if experimental results were different, suggesting that new conservation laws could be assumed based on those results.
Participants generally agree that empirical evidence plays a critical role in the formulation of electromagnetic laws, but there is no consensus on whether these laws can be derived solely from fundamental principles or if they require specific empirical observations. The discussion remains unresolved regarding the best foundational approach to understanding Faraday's Law.
Participants express uncertainty about the derivation of electromagnetic laws and the assumptions required for their formulation. There is also a recognition of the limitations in deriving individual laws from fundamental principles without resorting to empirical observations.
Ozgen Eren
I am having trouble with deducing the origin of Maxwell's Laws, especially Faraday's Law. Obviously some of the laws has to be originated by experiments and the rest should be mere deductions.
I would guess that Lorentz force law is the empirical information where we just named some terms as magnetic field following the experiments. There actually we can also deduce the EMF induced for a moving coil using Lorentz force. Then we get Faraday's law for non-changing magnetic field.
However how do we know that EMF will be induced if we vary B but have stationary coil? For example if I have a line of current and a coil nearby, EMF will be induced if I change the current even if I don't move the coil. Why is that? How do we support this apart from experiment? Can we derive it from Lorentz force law or did we just observed it?
(Saying "EMF is induced because flux changed over time" is not really an answer because it obviously is subject to the same question, why would the change in flux would lead to EMF. How did we know this)
You can say that the local (differential) Maxwell equations are the collected wisdom about the electromagnetic field in condensed form. You can motivate them from group theory and symmetries of relativistic spacetime but not really derive without empirical input.
I see, then we could not have Maxwell's law without Faraday's Induction Experiment right? It all boils down to this discovery along with discovery of Lorentz force.
None of Maxwells laws can be derived from the others to my knowledge.
They can all be derived from other starting points, like gauge symmetry, charge and flux conservation, etc.
Can you suggest an example for Faradays Induction Law? Are we able to define it with using only common sense starting points such as charge and mass conservation
(but not gauge symmetry nor flux conservation as they are more abstract ones. I mean I cannot ask why flux conservation took place but not conservation of *some other abstract mathematical quantity* did not take place. It feels like that would lead a loop that way)
In short, I'm just curious if we have any better explanation than: "Faraday's Induction Law is just the way it is, we noticed it and we are making use of it by deriving other relations by it"
Usually you cannot tease them out that finely. You make some assumptions and you get all of Maxwells equations, or half of them. I don't know of any which derive just a single equation.
Here is the one that I mentioned which assumes charge conservation and flux conservation.
http://arxiv.org/abs/physics/0005084
Thanks for clearing that up. One last follow up question:
If experiments shown Faraday's induction law to be formulated differently, say some weird physics law like "increase in current has a cubic effect, increasing Area reduces induced EMF etc", we would still do the exact same thing then, right? We would just assume conservation of an invented quantity instead of flux, and show that experiments are consistent with conservation of that quantity, therefore it(flux like quantity) may be assumed to exist although it cannot be perceived by itself in any way.
(That is of course when its possible to have conservation law by that weird physics law, I am not sure if is possible with nonlinear relations.)
Yes. With the caveat that I don't know if the specific results you mention could be made consistent with a Lagrangian of any form. Assuming that it could then, yes, any symmetry of that Lagrangian would be a conserved quantity.
  • · Replies 27 ·
  • · Replies 25 ·
