What Causes Frame-Dragging? Explained in Vernacular
  • Thread starter Thread starter Warp
Warp
My question is simple, although I suspect the answer may not be: What exactly causes frame-dragging?
I'm not very adept at understanding GR equations, so you'll have to explain it in vernacular.
I find the concept of frame-dragging very interesting. One could posit the question: "If a black hole is rotating, how would you know which way it's doing so?" A very naive understanding of black holes would answer that you don't. However, the correct answer is that you measure frame-dragging in the vicinity of the event horizon (which can theoretically be done simply by dropping an object towards the black hole and seeing which direction it starts to move as it falls.)
(Another naive question would be "how can a point rotate? It has no dimensions, and thus can't possibly rotate." But the correct answer is that the singularity of a rotating black hole is not a point, but a ring, which is what "allows" it to rotate, so to speak.)
The concept of the ergosphere, which is caused by frame-dragging, is even more interesting. It baffles the mind that distances within the ergosphere may increase faster than c from the point of view of an external observer... which just raises so many questions.
I sure can't attempt a mathematical explanation, but I'm sure there are people here who can.
I'll place a dollar on gravity in the GR sense, and angular momentum in the Newtonian sense, being involved somewhere.
Your naive questions come from a very basic misunderstanding of relativity, which I see turns up in this forum a lot. In fact, Einstein regretted calling his theory a theory of "relativity" because of exactly these kinds of confusions; he wished he had named it the "theory of invariances" instead, because it is really a theory about what is invariant when you change frames from one observer to another.
The fundamental misunderstanding I am talking about is the notion that "everything is relative". However, this is not true. Only velocity is relative. No observer can measure his own velocity in empty space, because velocity is only defined relative to other objects.
Acceleration, however, is not relative. An observer can measure his own acceleration with an accelerometer (a very simple device; you can attach a weight to a spring, for example). What an observer measures with an accelerometer is called that observer's "proper acceleration", and this includes the observer's rotation, which is a kind of acceleration. So rotation in empty space is real; it can be measured.
Your question of "Can a point rotate?" is more subtle than you may think, because an (idealized) observer is not just a point. An observer is a point with a local frame attached (a frame is a set of 4 orthogonal vectors, aligned along some choice of X, Y, Z, and T axes, which effectively function as the observer's set of measuring rods and clock). This frame can be made to rotate, and this is measurable.
P.S. The notion that "everything is relative" including acceleration is what is known as "Mach's principle". Einstein initially toyed with this idea, but in the end it turns out that GR is not Machian.
Why do you think this?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
