What Causes Quantum Energy Level Degeneracy?
soxymoron
I'm not going to follow the form because this is more of a hand-wavy question, I don't need it for a specific homework question but it's confusing me, I hope it's still okay to post here.
I understand the splitting of energy levels due to j (dependant on l and s) and I understand that each of the split states contains multiple degenerate states. What I don't understand is where they come from.
For an example of l=1 the energy is split into a j=1/2 and a j=3/2 levels. I know 6 states in total are contain within this split 2:4. This is the bit I don't understand, I'm assuming that the degenerate states are caused by the quantum number m but if that's the case why aren't they split evenly 3 to each energy level?
Thanks for any help you can give me
It's because the interaction that splits the energies of the state is the spin-orbit coupling, proportional to \vec{L}\cdot\vec{S}, which can be rewritten as being proportional to the difference \vec{J}^2-\vec{L}^2-\vec{S}^2, which is dependent only on the quantum numbers j and l (s=1/2 in either case): so that's why the l=1 levels split according to their j quantum number, and not m.
In a magnetic field, on the other hand, the additional splitting would depend on m.
right... but i f you want to go deeper... see the rapresentations of angular momentu in QM, see what are the wieight of a reprs ;)
Okay so m only comes into play when a magnetic field is added, that makes sense. Though I'm still not sure why j=1/2 contains 2 degenerate states and j=3/2 contains 4. Also, I have a question which asks me to 'estimate the weak Zeeman splitting of a system', my main problem with that is I'm not sure what the weak Zeeman splitting of a system is. I could calculate it for each state but I don't know what that would mean for the whole thing.
For j=1/2 there are two states: m=+/- 1/2, and for j=3/2 there are 4 different m-states.
The "weak" Zeeman effect just refers to a situation where the energy shift due to the magnetic field is small and can be treated with perturbation theory: the unperturbed Hamiltonian has split the l=1 level into 2: j=1/2 and j=3/2, and then the Zeeman effect splits each of those into 2 and 4, respectively, different energy levels.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
