What chemical should I use to etch away tin?
The discussion revolves around the challenge of etching tin compounds from a metallic surface composed of palladium, copper, and silver. The user seeks chemical solutions to remove tin oxide deposits at a microscopic level. Suggestions include using strong bases, which can dissolve tin oxide while being safe for the other metals present. The user also mentions plans for proper hazmat disposal of the chemicals used in the process. Overall, the focus is on finding effective etching methods for tin compounds without damaging the underlying metals.
Klausius
I am having difficulty in finding a solution that can etch away tin compounds in my metallic surface. The metallic surface has a composition of palladium, copper, and silver. There is a tin compound deposited on the surface which I would like to etch away or remove. This is on a microscopic level. Please help me. Thanks in advance!
Welcome to the PF, and you're welcome in advance. :smile:
So can you say more about your project please? What is your plan for Hazmat disposal of the end products of your process? What volume are we talking about? Micrograms or gallons?
What have you found in your reading so far? Can you share the MSDS documents that you've found so far for the prospective chemicals for your project?
I see from your New Member Introduction post that you are a professional working ChemE. Welcome That means you are familiar with MSDS considerations, and I'm looking forward to your relply. Thanks.
Klausius said:
I am a chemical engineer by profession based in the Philippines. I am expecting to create connections with you guys and build friendships as we help each other develop and expand knowledge on our respective fields.
Messsage me!
Likes Bystander
Hello! This is a microscopic view. I have a wire made up of Palladium, Copper, and Silver. There is a dirt on the wire surface made up of tin compound. I want to remove it using a certain chemical that can etch all the tin compounds away so my wire is dirt free. Can you suggest me chemicals to use? Thanks. and sorry for the late reply. :)
With regards to Hazmat disposal, since it is only a microscale. The chemicals that will be disposed will only be poured in a reagent container for waste. or it depends on the chemical that I will be using on how to dispose it properly, or if there is needed any additional processes to safely discharge it to the environment. :)
Thanks for your replies and clarification. I think I will page @Borek to help with your question... :smile:
Thank you so much @berkeman ! Looking forward to hearing from all of you. :)
Do you know what tin compound it can be?
Could you use mild abrasive cleaning ?
Tin oxide can be soluble in strong bases, that should be safe for your other metals.
