What CM frame to take in this case?
  • Thread starter Thread starter physciencer
    Frame
physciencer
If an electron-positron is decaying into Higgs and then from Higgs into fermions. What is CM frame in this case?
Let us say that electron has momentum $$p_{e^-}=p_1$$ The positron has a momentum $$p_{e^+}=p_2$$ The fermion has momentum $$ p_{f} = q_1$$ and the other one has momentum $$p_{\bar{f}}=q_2$$
The CM frame is always the same, i.e. the one where the total spatial momentum is zero. In this frame you have that the initial e+e- pair have total four-momentum ##p_1+p_2=(E_1+E_2, \vec{0})##. However, by conservation of four-momentum it must also be ##q_1+q_2=(E_1^\prime+E_2^\prime, \vec{0})##.
That does not make sense - neither the electron nor the positron can decay to a Higgs, and a combined object (positronium) cannot do either.
You can produce a Higgs in a high-energetic collision of electrons and positrons, but the direct production (a Higgs and nothing else) is very unlikely due to the small mass of the particles.
SO yes that is what I meant, that you can produce a Higgs in that way. If so, then the CM is how @Einj posted, no?
@Einj, how would I find invariants in this case?
It depends on what invariants you want to find. What do you have in mind?
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
