HowlerMonkey said:
The mod motors came from Yamaha's work and I'll bet quite a bit of patent licensing...and likely a few undisclosed agreements.
I've worked on both mod motors (2700hp) and lexus engines and yamaha design is all over both of them.
Understand, I usually don’t have any interest in the opinions people have concerning any manufacturer. I have no reason to defend Ford or challenge your opinions about them or their products. I honestly don’t care but you have entered into the thread comments that are erroneous but with history.
For students, Ronald Reagan once said, "Trust but verify." You are pursuing a profession that is replete with "conventional wisdom" and "common knowledge," that is often easily proved to be wrong. This Yamaha and Ford stated relationship is a good example of wrong.
Starting with Lexus, Haruhiko Tanahashi is an outsourcing genius. The company is a division of Toyota which is in control of most Lexus production but beyond that they are almost hands off. That said, Lexus has rather small engineering and design departments taking advantage of Toyota’s accessible resources. Except for the LFA, Lexus engines are Toyota’s. Granted, in I believe 2000, Yamaha entered into a relationship with Lexus concerning the LFA engine but again, 2000. I would need an explanation of how you see Yamaha all over Lexus engines. In fact considering the history of Toyota and the history of Yamaha when it comes to automotive engines I suggest it would be easier to find Toyota in Yamaha. That is except for the LFA engine but this is to be explained.
About Ford, the Modular Motor as a Yamaha came about from competitor marketing in the guise of "Automotive News," and was made worse by bad, sloppy and biased journalism. Good journalism has debunked the premise.
If the modular was based on Yamaha designs, so what? It is common practice by all manufacturers to reverse engineer competitor products and take advantage of any improvements when and where it can be done. It will be rare when you see something that can’t be directly traced back to someone else’s work. This is one reason why patents relating to engines are rare and "one" of the arguments that led to George Selden having his Patent on the automobile taken away in court by Henry Ford.
"I'll bet quite a bit of patent licensing...and likely a few undisclosed agreements."
This statement tells me a lot and you'd bet wrong. With your Modular experience please explain what there is about the motor that would lend itself to a patent?
The first concept to get a handle on with the Modular Motor is that the Modular has nothing to do with the performance of the motors or how they work. Modular refers to the production process. The Ford 5.0 Coyote Motor is a Modular Motor and by no stretch of any imagination can the Coyote be compared to the 4.6 or 5.4L Modular Motors. I believe the only common part between them is the lifter.
Now about Ford and Yamaha. Ford and Yamaha have a long history of partnerships and joint ventures and yes Yamaha was involved in the development of the Modular Motor. Some news from the time reported Ford hired Yamaha but the financial statements from the time debunk that. It was a joint venture primarily in production techniques and technology. It should also be noted that Ford Europe, Australia and Asia have a history with Yamaha that predates any relationship with Ford, North America. I could be wrong but I believe the year of the joint venture was 1991 debunking any notion that Ford possibly benefited from the LHA engine. If anything, the LHA V10 engine chased the modular 6.8L, V10.
HowlerMonkey, can you explain how you see Yamaha in the modular motors? Modular motors have square and under-square configurations. Except for maybe the outboards which I know nothing about, Yamaha’s are over-square designs. Yamaha’s power curve peaks in the mid 7’s while the modular peaks in the mid 6’s. The top end of the motor designs are different. I could go on but why pursue a statement that has no source reference?
Considering the bottom end. I'm not aware of Yamaha ever making a production engine with a flat plane crankshaft until their partnership with Ford on the V6 SHO motor. The flat plane was a design spec from Ford. Yamaha was known for its cross-plane cranks. This is not a statement on the benefits or drawbacks of either design. It's a statement about obvious and critical differences in designs.
The V8 SHO motor was based on the Ford Duratec motor and not the V6 SHO. Yamaha then designed a motor for Volvo. A transverse, front wheel drive V8 based on the V8 SHO. The necessary counter balancing design changes aside, the Ford V8 SHO is all over the Volvo motor from Yamaha.
In all my working years I never got over how unaware people are of the cooperation and sharing that goes on between most manufacturers in the automotive industry. It's an odd psychology reinforced by the manufacturers. An example of where "most" doesn't apply is with the Cosworth, Chevrolet Vega. When it was available it was Chevrolet's most expensive car except for the Corvette. Chevrolet spec'd the engine and both Ford and Cosworth told Chevrolet it was a bad design. Chevrolet said to build it as spec'd and the car was a colossal failure. Because of the Ford\Cosworth relationship at the time neither wanted to be associated with the car. Everybody had egg on their face over the fiasco. This was all part of DeLorean's years at GM and led to probably the worst decision GM's ever made. GM decided to pull back design and engineering from the divisions to the corporate offices and that decision was a disaster. It led to GM's lean years in the 70's and 80's. Most manufacturers understand that whatever happens in the industry has repercussions throughout because everything about heavy manufacturing has been interdependent for years. It's only the "Boutique" builders that live in a vacuum. Even in racing the amount of cooperation found in Motorsport Valley is impressive. Everyone understands what proprietary means and they know when it doesn't apply.
The point of this being your observations about the Modular Motor's is in error but even if your perceptions were correct, so what? It doesn't matter either way to the manufacturers. The statement of payoffs and patent infringements is about a lack of insight into the industry. The perception and reality are very different.
What’s in this post just scratches the surface.
RangerMike, I'm going to a symposium next month on additive manufacturing even though I'm retired. Solid modeling was a game changer and additive manufacturing may have just as much of an impact. It was novelty when processes were changing and replacing traditions like clay modeling but improvements in materials and processes has opened up once unheard of possibilities. What was not long ago simple layering is becoming the construction of woven, long polymer chains. Imagine designs like the old Allard's questionable twisting frame as part of the suspension dynamics but potentially coming from a seamless, one piece frame with the strength of carbon fiber. I've heard rumors of some whiz kids in Asia completely redesigning the side impact area based on a lighter and stronger honeycomb design. It's work that is being done with a faith in what they believe is inevitable and coming. That's an engineering mindset that's a game changer.
Last post so best of luck to all.
