What does the magnetic field look like in a torroidal coil?
The magnetic field within a toroidal coil is characterized by field lines that circulate uniformly inside the torus. As the coil is bent into a toroidal shape, the magnetic field lines become confined within the coil, with minimal external field presence. The discussion emphasizes interest in understanding the magnetic field's shape and intensity both in the central region of the toroid and extending outward. The tokamak configuration is mentioned as a relevant example, highlighting the uniform direction of the magnetic field lines. Overall, the focus is on the external magnetic field characteristics of a toroidal coil.
Driftwood1
The magnetic field within a torroidal shaped coil is well understood.
In a standard cyclindrically shaped coil there are magnetic field lines that along the axis of the coil and continue outside the coil and bend around to eventually join the other side of the coil.
If we were to bend this coil, what do the magentic field lines look like as the coil in bent closer and closer towards a torroidal or donut shape?
I am interested in the magentic field shape and intensity outside the boundaries of the coil. That is in the central space of the torroid and also outside the coil.
Any suggestions?
I am a plasma scientist, so I know quite a bit about magnetic fields. What you wish to know is a tokamak style magnetic field. You get a magnetic field that are field lines inside the torus spinning in uniform directing.
When you say INSIDE the torrus I assume you mean within the coil boundaries?
My query relates to the shape and intenisty of the magnetic field outside the torroidal coil - in the central region and outside the coil going off to infinity.
Can you assist here?
I will look up Tokamak magnetic field - thanks for that
(I have also looked up polloidal fields which are also interesting)
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
