What does this order symbol mean?
  • Thread starter Thread starter fedaykin
    Mean Symbol
The order symbol discussed is represented as \mathcal{O}, indicating "order of magnitude." It signifies that a quantity is on the order of 1, meaning it is greater than 0.1 and less than 10. In mathematical contexts, such as x \sim \mathcal{O}(\lambda^n), it describes the size relationship between variables. The term "O(1)" specifically implies a range of values, while "O(1032) years" denotes a proton's lifetime being between 10^31 and 10^33 years. The discussion also touches on the relationship of similar symbols in TeX bitmap naming.
fedaykin
Mathematics news on Phys.org
It means "Order" as in "order of magnitude". \mathcal{O}(1), when referring to some quantity, means that the order of magnitude of the quantity is on the order of the number 1 - it's larger than 0.1 and less than 10. Typically we take order of things as powers of some number.
e.g. x \sim \mathcal{O}(\lambda^n) means the variable x is of the same order of size as the parameter \lambda to the nth power - it's between \lambda^{n-1} and \lambda^{n+1} in size.
See http://en.wikipedia.org/wiki/Big_O_notation
That is "on the order of". Its most general mathematics definition can be complicated but in this application saying "O(1)" really means "a few": less than 10 but more than 0.1. Saying that the lifetime of a proton is "O(1032) years" means that the lifetime of a proton is certainly greater than 1031 years but less than 1033 years.
Thank you oh so very very much. I've noticed that there are letters that take a similar tex bitmap name; are they related?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
