What Exactly is Alternating Current
In summary: I forget the reason.Yes, in alternating current the electrons flow first one way then the other, back and forth. This is useful because one can use a transformer to convert from low voltage alternating current to high voltage alternating current.
noname2020x
I understand direct current perfectly fine as it is just the continuous flow of electrons, but what is alternating current. I have heard it explained as the continuous switching of a currents direction 50 or 60 times a second, but that is so vague and confusing. Do the electrons move back and forth? Why would this type of current help?
yup! :biggrin:
(a very short distance, not all the way to the mains and back)
suppose you're trying to heat an ordinary heating element …
all that matters is how fast the electrons are moving through it. not which direction they're going in
obviously, the power is sometimes zero, but it's never negative, so it heats fine! :wink:
(i forget the advantages of AC … something to do with lower transmission losses, i think … but you can easily look that up)
A transformer is essentially a pair of coils. A changing input electrical current through the one coil generates a changing magnetic field. The changes in the magnetic field experienced by the other coil induces an output electrical current. If the number of windings in the output coil is greater than the number of windings in the input coil then the output voltage can be greater than the input voltage. If the number of windings is lower then the output current can be greater than the input current.
Note that energy is conserved. The output voltage may be higher. But the output current will then neccessarily be lower and conversely, the output current may be higher but the output voltage will then neccessarily be lower.
By contrast, a constant direct current flow produces a constant magnetic field. A constant magnetic field does not induce an electrical current. So a transformer will not work to convert low voltage DC to high voltage DC.
yes.
The transmission loss in a wire goes as the square of the current, while the amount of power transmitted is equal to the voltage times the current. So the efficiency goes up as the voltage increases; you can move the same amount of power with less current and hence less transmission loss.
But at the point where the power is produced, you want to work with whatever voltage gives you the best mechanical efficiency out of your generator; and at the point where it it used you want whatever voltage matches the need. So it's very desirable to be able to step the voltage up and down, and as jbriggs said, that's much easier with alternating current.
this may be true for the "ordinary" heating element. but it is not necessarily true for anything with a "reactive" component. if you hook your AC up to a capacitor, you will have voltage and you will have current (both AC) and half of the time the power going into the capacitor is negative.
it's much much harder to make a transformer (to step up or step down voltages) that works for DC.
for transmission, the losses that are due to the flow through the cables are [itex]I^2R[/itex] which means that by lowering the magnitude of current [itex]|I|[/itex], you lower the loss. to do that and still transmit the same power, you need high (really high) voltages. to convert to/from high voltage from/to low voltage, and to do that efficiently, you need a transformer. and basic transformers don't work for DC.
that said, there are now modern high-voltage DC transmission lines for dedicated transmission of power (they're not connected directly to "the grid"). so evidently the DC lines have less loss than the AC lines (i think due to what is called "skin effect" that decreases the effective cross-section for the current flow and increases the cable resistance). so, evidently, the difficulty of converting from AC to DC and back to AC again, those losses must be less than the losses avoided in the transmission line by going with DC.
The DC transmission of power is much more appropriate for use with undersea cables such as the quite small system between England and France or the much larger schemes contemplated to bring geothermal power from Iceland to Scotland or Germany.
When AC is used with undersea cables there is considerable loss do to the current flowing in and out due the capacitance of the cable.
I can't understand this preoccupation with discussing electrical phenomena in terms of electrons - as if it will really help with understanding. Tiny Tim mentioned that the electrons in AC don't get very far. The actual distance that they do travel is worth mentioning. In simple terms the average drift speed of the electrons in a metal is in the order of 1mm per second. Now you have to realize that, with 50Hz AC, they are only drifting one way for 1/50s so that implies a maximum movement of around 1/50mm in either direction. At the same time as this really slow drift speed, you also need to realize that the (conduction) electrons in a metal are thrashing about randomly in different directions at very high speeds due to thermal agitation - much much higher speeds than this snail-like drift speed.
Does that really help in the understanding of what is going on in the miles of cables of the National Grid or in a Transformer, motor or light bulb? Electrical Engineers (who are the people who tend to know and understand these things) pretty much never refer to electron movement because it is Irrelevant. If you just treat electricity as a net flow of charge in one direction or another, which causes a very rapid transfer of Energy from one place to another you will start to get somewhere. The word to use is Current, which is all you need to consider. Expecting electrons to help ones understanding is a delusion, based on notions of water flow - possibly worse than the water flow model.
The only aspect as to which the model of waterflow would be accurate to an extent is the fact that the time it takes for electricity to reach far distances in a conductor is very very small as to the EM wave that it makes and which travels near the speed of light in non vacuum conditions.
Just like when a pipe is already full of water all it takes to make the water come out in one end is to supply more water at the other end.
I am sorry if this is not a desired or unscientific explanation
Absolutely. It's very limited but vaguely useful when waving arms about. As with the electron-based discussion of electricity, it is deceptive and can give a very false sense of understanding.
But to a person who seeks deeper answers and knows some basic things very well the electron part of electricity may only come as a further deepening of knowledge I guess it's just about how seriously we take things that we want to learn and understand.
Too many people think they fall into that category but, if they need electrons to describe what happens in a circuit, then they clearly do not belong there. If you are involved with the details of semiconductors, superconductors, Hall Effect, etc, then electrons may come into it. Using electrons to 'explain' how a circuit works is a fruitless exercise. 'Electricity' is not a concrete phenomenon and needs to be treated with due respect before you can expect any understanding of it. It's the equivalent to trying to describe Differential Calculus with a pile of beans. Why do people have a different attitude to pure Maths from their attitude to Physics theory, I wonder? They both require formal thought processes.
There is another real risk when your hypothetical 'informed' person tries to explain using electrons - they give the erroneous message to the 'uninformed' that 'electricity' is trivial.
Well maybe because in pure math as you said there are specific numbers and equations going on and there is no room for blind guesses or even close speculation you have to know what your doing to solve those equations. While in theory you can make analogies and try to make imaginations of those processes and it is easier then.
Also there are more people which can't understand a BH from a mathematical formulation but they have a clue about a BH when they are being told about the physical processes going on around it and close to it.I believe even many high school students learning physics get a clue about some proceses only after they are introduced the story of it not the numbers and equations. And then when they have understood the story behind it they put in the numbers and see how it works out.Well I do that kind of way too.Maybe not the best way I agree but what else a chance do I have if I can't handle math that good.?
Speaking of myself and electrons I love physics and I think I understand physics quite well for a guy my age(23) and educational background (not that big) but I have to admit mathematics is not my strong side and that causes some problems and slows down my ability to construct different electrical equipment but I still love the process.Even though everytime when I come up with an idea and start to build it i realize that the world has built or tested that already.
I mean there is so much knowledge already know to human that to catch that is almoust impossible.
Basically the previous post about the person who seeks deeper was about myself... :D
@Crazymechanic
I understand what you are saying but I still hold that, if people don't feel comfortable with applying the simple formulae that are used in basic electrical circuit work then a model based on pushing metaphorical peas through a tube is not really going to help them much in improving their understanding or ability to predict what will happen in a given circuit.
Going from V = IR to 'electrons going along a wire' is a backward step.
I still love the process. Even though everytime when I come up with an idea and start to build it i realize that the world has built or tested that already.
That's absolutely fine and very few of us can ever help to make significant original contributions. The pleasure is always there when something works that we have devised. We all get that glow of pride when the lamp actually does light up when we first press the switch or the display lights up and shows us the right characters.
Personal pictures of what happens in electrical circuits are fine as far as they go but my worry is when those pictures are often presented in forums like PF as being 'gospel'. They tend not to be presented with all the necessary caveats as to their validity and can serve to muddy the waters for people who really want to find out more.
If you want to get deeper into the subject then my feeling is that you really need to get away from the 'concrete' and into the stricter, formal ideas that have been established. For instance, it is far more fruitful to talk in terms of 'charge' than 'electrons' because talking about charge encompasses all ways in which electric current is passed and avoids all the random aspects of electron movement and QM. It's a bit of a generational thing (I may even have a tiny chip on my shoulder) but, when I was taught 'electricity' initially at school, we just talked about charge and were strongly discouraged from touching on electrons on the grounds that they would confuse us. My teachers were proved right because later generations of students were all told at their Mother's knee about particles. Consequently, these pages are full of confusion generated by the perception that 'Scientists got it wrong about the direction of electric current'. At an appropriate time in my Science education, I easily came to terms with the negative sign of the charge carriers in metals and there was no confusion.
"""@Crazymechanic
Going from V = IR to 'electrons going along a wire' is a backward step."""
Basically I agree to what you say.It's like a grandma doesn't need to know the molecular composition of milk to know that her cat certainly likes it.Also I first hear and learned electricity from the observations about what she does starting from few nasty shocks as a little boy up until all the parasitics and EMF from large transformers and other things when built my first amplifier in school.And now when I know the basics I can try to step further and visualize electricity in terms of electrons but even though I may fail at some point of that deeper visualization that will not erase all the fundamental laws that I know about electricity as a phenomenon not as a force carried by certain elementary particles .
So fundamentally I agree with you as I think people should start to learn things in the order in which they were invented and after that they can build up some more advanced bricks of today's science.As it would be funny and stupid to know the flow of electrons in the opposite direction to that of the current and not know Ohm's law.
Crazymechanic said:
"""@Crazymechanic
This says it all, I think. What anyone 'visualises' is not necessarily near what is the accepted model so how is it helping at all (apart to make them feel better)? It can be a positive disadvantage if they then want to take things further. Of course, everything we 'know' is based on analogy and models - unless it is really basic - like Grandma and the milk.
Piling onto a Science and assuming, on no firm basis, one has an understanding, just using a personal model, is a bit like making up your own version of French and expecting it to have any meaning to a French person. My particular bugbear is even worse than the electron thing - it's when people talk of photons as if they have the remotest resemblance to little particles streaming through Space from one point to another. Nobody who has a deep knowledge of these things would give such a model houseroom (or brainroom) yet the notion turns up on a daily / hourly basis when EM waves are discussed.
My only real worry is that people's personal pictures can be passed on and received by the uninitiated as if they constitute 'real Science. This does no one any favours.
AC is necessary to transform the voltage down or up in a transformer. It is also necessary to run electro motors. Either the AC is made inside the motors windings via commetators (Brushed DC motor), or the AC is fed directly into the windings (Brushless AC motor).
The frequency is a drawback for transporting energy over long distances. The frequency will cause loss due to the inuctance of the long wires that transport electricity. DC would be the best option for the transport part, but DC cannot be transformed down to a voltage that can be handled safely. Transportation voltages often exceeds 50 000 Volts to keep the current as low as possible. As current will cause loss over such a long distance with an increased resistance in that cable the longer it is. Keeping the current low, will cause less energy loss.
50 or 60Hz is standard frequencies. An AC motor depends on this frequency to perform a given RPM. Except for the number of poles in the stator and the rotor, the RPM is set based on the input frequency.
Vidar
It's interesting to note the contrast between the quote and the response in the above post. The use of 'electrons', which is in the quote (noname2020x) is totally ignored in the response (Low-Q). Clearly, the response is from someone who has more knowledge of electricity and realizes that bringing electrons into the topic really doesn't help.
I wonder if the message has sunk in yet. It may be possible to give some sort of limping explanation for DC using electrons but trying to take them with you to into AC explanations (and the way that transformers and synchronous motors work, for instance) is fruitless.
@sophiecentaur : By that visualizing I meant as close as possible to the model physics knows the best.It's not like one just hears a word and then makes a totally self sustained story out if it atleast not in my case. It's rather you read the most accurate theory to date and try to grasp it , ofcourse there will be some misconceptions from person to person I guess that's just human nature.It's like 10 persons traveling down the same road with the same map and still after the trip everyone will have a slightly different account of how the road looked like and what was there.Same in physics and even worse as the things are much more complicated and in the case of electricity- hidden from the naked eye.
Ah the photons , let's be honest understanding all these things can be compared to the world's economic situation , there will be rich people there will be middle class and there will be poverty and homeless people not to go into detail it's just the way things are because of how we live how much we understand and want to do.Same in physics if someone understand something good then that isn't a sign that some other will understand those things even close.
The only responsibility to those who know is to spread the knowledge as unedited and close to the truth as possible.
@Low-Q:"adding to what you just said is that nowdays DC lines are starting to evolve as we have high power thyristors and all kinds of "smps" equipment to step up or down even high voltages of DC and to then invert those to usable AC mains.
A German company "ABB" and "Siemens" are currently building such high power DC 800kv lines in China.
http://http://www04.abb.com/global/seitp/seitp202.nsf/0/5392089edc1b3440c12572250047fd78/$file/800+kV+DC+technology.pdf
@By the way "sophiecentaur" is right because in electrical equipment there are very rare times when something from the quantum level of physics needs to be considered like electrons for example of photons in EM vawe, so when it's not needed we can survive with the classical laws of electricity that we all know better of like Ohm's, ampere's and others.Each level of competence has certain things you need to know but not more, like a guy who repairs tv sets probably doesn't know quantum mechanics good or even at all but that doesn't make him a bad repairmen I guess as long as he is in his field of expertise.
Crazymechanic said:
@sophiecentaur : By that visualizing I meant as close as possible to the model physics knows the best. It's not like one just hears a word and then makes a totally self sustained story out if it atleast not in my case. It's rather you read the most accurate theory to date and try to grasp it , ofcourse there will be some misconceptions from person to person I guess that's just human nature.
My point is that the model / visualisation of electrons circuits that most people carry in their heads (due to what they're bombarded with at School and on TV) is damagingly flawed and leads them to seriously wrong conclusions if and when they start to think about it independently. It's not merely inadequate; it's bad, imo and it really has no place in PF discussions - or even the discussions in secondary schools. It's nowhere near the 'closest model'.
Back to photons: The picture that people (yer average Jo public) have of photons is a throwback to the old Corpuscular Theory of light that went out about 400 years ago. So much for Science education.
As much as I recall there were some good threads here on PF about the electron/electricity topic and some people with advanced knowledge explained those things pretty well I'm not saying this should be the topic whenever someone wants to wire a light bulb in his garage but if someone really is interested in what he learns he can find not only tv and public misconceptions but also good info to read.
And thanks "sophiecentaur" for your effort as being one of those who rings the bell everytime some wrong or misunderstood words and theories come up.
Let's keep up the good work.
I don't see how this improves anything at all since:
In practical terms, the ampere [unit of current] is a measure of the amount of electric charge passing a point in an electric circuit per unit time with 6.241 × 1018 electrons, or one coulomb per second constituting one ampere.
http://en.wikipedia.org/wiki/Ampere
If you try to talk about a flow of charge and or current, that charge and or current automatically refers to a specific number of electrons passing a point per unit time, by definition. I don't think the model of electrons moving along the wire is the idiosyncratic and personal model you make it out to be. It's a standard definition of current as far as I can see. Therefore, your correction completely confuses me.
Of course there's no question that Current is Charge per unit time and that implies the net transfer of electrons in many or even most cases. But current doesn't always involve electron movement, for a start.
Are the sub atomic distances traveled by electrons for high frequency AC really a suitable way to describe what goes on? The actual speed (mean drift speed) of the conduction electrons and the distances traveled will depend upon the geometry (thickness and length of wire, for instance) and also the metal involved - do you want to bring that into each description? Is it relevant? What has any of that got to do with the operation of a circuit?
Just what is the problem with using the quantity Current? It is, I admit, a slightly more abstract concept than peas flowing in and out of the ends of a pipe but electrons aren't actually like peas in a pipe in any case.
How would you use the concept of electrons flowing when describing the situation in a Capacitor or a Radio Antenna? Current, on the other hand, gives you a seamless join between the wires, the fields and the waves so why not accept that it's clearly the way forward. I seems to me like a bit of inverted intellectual snobbery at work when people insist on using an elementary and flawed model in preference to a far more appropriate one.
Current means electron flow. It's a current of electrons (except in the case of ions). Therefore it should not be considered wrong to speak of electrons moving in one direction or another. It's confusing to me that you're insisting that one term for the same thing is vastly superior to another. If the electrons only move some subatomic distance in high frequency AC, for example, so too does the current only move some subatomic distance. Likewise if we speak of charge. Everything wrong with electron flow has to be equally wrong for current and charge because current is electron flow and electrons are charge. Such is the definition every text gives me, anyway. It sounds like you're saying, "We can speak of traffic but talking about the motion of cars on streets is inverted intellectual snobbery." The word "current" doesn't banish the image of a bunch of electrons moving through a wire, or vibrating back and forth in it, from my mind. Neither does "charge".
I have three fat modern 1st year physics texts here among my books and all three maintain that when you have current it's because electrons are moving generally in one direction under the influence of an electric field. Two of them go into meticulous detail about this motion being only a very slow drift (no peas in a pipe here), I'm sure you'll be glad to hear, but I think it's possible you may be up against just about every textbook there is in insisting that people not think of current, or the motion of charge, as moving electrons.
AC: The current is moving back and forth, the charges are moving back and forth, the free electrons are moving back and forth. All three equally correct, as far as I can see.
You are entirely missing my point here. I am not arguing against describing electric current in terms of electrons, of course, because they are the majority carriers in most circuits. But current can just as reasonably be carried in the form of ions, positive electrons or holes (which are all equally valid entities - maybe, just a bit less common). My problem with the free use of the term electron -as if it actually 'explains' anything - is that people who use the term seldom have a clue about what an electron is. They are using the most concrete sounding term that they can lay their hands on rather than admitting that they are dealing with a very abstract concept called electricity. They are using a term which they assume is somehow more fundamental and 'easy' when all they are really doing is reaching for the nearest thing to the 'peas in a tube' model. How does electron flow actually explain anything? Electron motion is a fact but just how relevant is it to a better understanding of 'electricity'? Let's face it, most aspects of the topic were well understood long before Mr Chadwick actually gave us electrons on a plate.
On the subject of textbooks, I would be interested to hear if you could quote an instance where any of your books deal with Kirchoffs Laws, AC theory, Inductors, EM induction and actually mention electrons in those particular sections. I would suspect that even K1 is described in terms of Charge Conservation. Text books discuss conduction through metals in terms of electron motion because it ties in very handily with atomic structure. This is, of course, a very good idea as it links two very different aspects of science. When a textbook talks of current in a wire and electron flow it is usually to demonstrate (with actual numbers) just how slow the drift speed is - to lay the ghost of electrons zapping through at nearly the speed of light.
I could leave you with one little thought about Displacement Current, which certainly involves no charge carriers at all but it is necessary if you want to describe alternating (time varying) currents properly. You can, perhaps, neglect it at 50Hz but Maxwell should really be considered if you want to give bomb-proof explanations to unsuspecting students. Use the word 'Current' and they will not come back later and tell you you got it wrong when you gave them the electron explanation.
(See this thread which is running concurrently).
I actually understand both of you either @sophiecentaur and @zoobyshoe
But in overall I think @sophiecentaur is right about one thing that in the start someone doesn't need to know what an electron is to learn some basic truths about the phenomenon associated with it.When I was like 7 years old I dismantled old tv sets and put the resistors and tubes in spare part boxes and ofcourse at the time I had no understanding of what was really going on in those parts I just had the love towards those things and I leaned to use the screwdriver and different tools to even get to them in the first place.But as years went on I learned more and more and now I am to the point where I would like to see the flow of electricity in terms of something deeper meanwhile not forgetting the simple most basic facts about the phenomenon as a whole.
I guess one could say it's like when a 5 year old asks his mom or dad what is the thing we call sex you won't go and tell him the whole truth and in the end for better understanding show him some tape or film about it.At that age you will explain this practice in terms of something a child would understand and in the same time that won't affect him badly.
These days there are a lot of little kids walking in streets using some rude words and phases and sometimes they don't even know the meaning behind them.
i guess @sophiecentaur is trying to say that we can get into this kind of situation if we try to "dig" too deep with little knowledge and a small showel.
But in the same time I can agree to @zoobyshoe .For the ones who have enough understanding and knowledge why can't they use what they like as long as it's the truth and represents the phenomenon equally or even better.
Ofcourse if we go deeper in terms of current as electron movement of certain amount in a conductor then I guess we have to also speak about the EM field and photons and how that affects the whole fast electricity thing with "super slow" moving actual electrons.Otherwise it would not be the whole picture.
And here I have to admit that even though I have a clue about the EM photon field working hand to hand with the passing of current in a conductor I don't feel so advanced to tell some deep facts about it fully ,well I know them to myself but I am not that sure about them that I could go on and teach others about them.So maybe we should create two threads on PF in which one would be the electricity for beginners with the basic things and the other one would be for the ones that want to go further.Where all the advanced and complicated phenomenon of quantum physics would be explained.And then when someone has a question judging by the context of the question he could find his answers there.More like a FAQ but in terms of for example "why is electricity fast when electron movement is slow"? I think these kind of questions appear pretty frequently.
Ofcourse if someone of the PF staff thinks that such an idea is meaningful or maybe something similar is already made.
You have summed it up quite nicely there. The only point I can add is to say that it is a very risky statement to say that you 'understand' what electrons are when you are not able to 'understand' electricity using classical terms. (that is the general you and not you personally) It may feel as though you are making it more concrete is some sense but, in fact, the electron is an even less concrete concept (if you really consider what it 'is') than the good old electric current which you can at least measure with a meter from the store on the corner.
Particles may seem like your friends but they can (and frequently do) lead you astray.
Related to What Exactly is Alternating Current
1. What is alternating current (AC)?
Alternating current is a type of electrical current where the direction of the flow of electrons periodically switches back and forth. This is in contrast to direct current (DC), where the electrons flow in one direction only.
2. How is AC different from DC?
AC and DC differ in their flow of electrons. In AC, the electrons flow back and forth, while in DC, they only flow in one direction. Additionally, AC is more commonly used for long-distance power transmission since it can easily be converted to different voltages using transformers.
3. What causes AC to alternate?
AC alternates because it is generated using an alternating current generator. This type of generator uses a rotating magnet to produce an oscillating magnetic field, which in turn induces an alternating current in the wire coils.
4. What are the advantages of using AC?
One of the main advantages of AC is that it can be easily transformed to different voltages, making it suitable for long-distance power transmission. Additionally, AC can be generated using a variety of sources, including hydropower, wind power, and nuclear power.
5. How is AC used in everyday life?
AC is used in many household and industrial appliances, such as refrigerators, air conditioners, and electric motors. It is also the type of current used in most power grids to supply electricity to homes and businesses.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
