What exactly is the definition of an EM wave?
An electromagnetic (EM) wave is defined as a change in the electromagnetic field that propagates through space, typically resulting from accelerating charges or changing magnetic fields. It is not necessary for the EM field to oscillate at a constant frequency; various frequencies can combine to create complex waveforms. The wave equation is linear, allowing for the superposition of different solutions, which means multiple oscillators can produce a resultant field that is not a simple sine wave. A moving electron can generate an EM wave, even if it stops, resulting in a single pulse rather than a continuous wave. The discussion clarifies that the term "wave" should not be confused with "carrier wave," which refers to a specific frequency.
k9b4
Do we say something is an EM wave only if the EM field is oscillating at a constant frequency? What exactly is the definition of an EM wave?
If an electron moves in a direction and then stops moving, is an EM wave produced by that electron?
An EM wave is a change in the EM field propagating in space. Its a signal that tells different parts of the space to update their value of the field. Any acceleration present in the charge distribution causes an EM wave. Changing magnetic fields may cause EM waves too.
No. The wave equation is linear, so any two of its solutions can be added to yield a third. Electrical and magnetic fields also add, so if I have two oscillators at different frequencies, the resulting electrical and magnetic field will also be a solution to the wave equation. It won't be a neat pure sine wave with a definite frequency, and by adding enough different frequencies and amplitudes you can produce almost arbitrarily complicated waveforms.
I don't know that there's a single exact definition, but I'd expect just about everyone to agree that any time-varying electromagnetic field that can be written as a sum of terms containing ##e^{i(kx-vt)}## would be one.
Yes. It will be a single pulse, but it will be a wave.
People often confuse the term "wave" with a "Carrier wave", which is a single frequency (sin wave) and of long duration.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
