- 23,750
- 5,949
Yes. I was referring the the pressures inside the water tank.sophiecentaur said:1 - do you mean the hydrostatic pressure on the outside ? Yes the pressure underneath is greater - producing upthrust. Upthrust is due to displaced volume and, for anything other than a basic cylinder / prism shape, the net upwards force is a pain to work out. What happens inside must be independent of shape (?? why not ??).
Did you ask this first question with something else in mind?
I don't think we are on the same wavelength.sophiecentaur said:2 - The pressures in an out or at the top and the pressures in and out at the bottom must be equal or water would be flowing so the weight of the water in the tank / tubehttps://www.physicsforums.com/help/bb-codes/s displaces its own weight of water (Archimedes). The weight of the metalwork will be the only thing that will contribute to what the green man feels. The question is whether the air pressure affects the net weight of the water tank. It the air is replaced by water then the water displaced by the tank metal would reduce the force as for a lump of the same metal under water. Perhaps it is in fact necessary to consider the pressures here and that would suggest that the apparent weight felt by the green man would be greater.
But I have a difficulty here because the actual shape of the tank would appear to be relevant and can that be?. A thick walled tank of less dense material would be affected differently from a steel tank. Are we looking at a 'mean density' of the water and air - say half the density of water??
3 & 4 - The water has neutral buoyancy and I can't see the presence of the bags can have any effect; water will always flow to equalise pressures on either sides of the bag fabric.
