What function or operation am I looking for?
  • Thread starter Thread starter minio
    Function
minio
First, I am sorry for very unspecific topic, but I really have no clue what I am looking for. I need some way how in mathematical terms describe things like following:
I have line segment of length l and I have sine function with period length \lambda originating at one end of line segment. If l=\lambda I can easily count that there will be three points on the segment where sine value will be 0. But If \lambda is slightly shorter there still will be three such points until l=\frac{3}{2}\lambda. Then there will be four of them. How can I describe number of such points as f(l,\lambda)?
What should I look for/study? Frankly I wouldn't be surprised if it is something really basic, because I tend to miss basic things :/ Thank you in advance
Mathematics news on Phys.org
So, you want to know how many zeroes are in a sine wave l/\lambda periods long. Which should be \lfloor 2l/\lambda \rfloor+1 zeroes in total, where the brackets represent the floor function.
Thank you. I never heard of floor function before. Now it is clear, that in general I was looking for floor/ceiling functions.
You're welcome!
If the ratio 2l/\lambda is positive (as it will presumably be in your case), then \lfloor 2l/\lambda \rfloor is simply the integer part of that ratio. For example, if 2l/\lambda was 17.936, then \lfloor 2l/\lambda \rfloor would be just 17.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
