- 37,494
- 14,384
The plastic tank is safer than hydrogen under pressure. It won't explode (as we are not in a movie). A burning car is bad, but an exploding car is worse.
jim hardy said:Folks far removed from the energy industry generally don't grasp the scale.
The world uses around a cubic mile of oil per year.
From http://spectrum.ieee.org/energy/fossil-fuels/joules-btus-quadslets-call-the-whole-thing-off
So start today building a hundred windmills every day.
At end of fifty years, if they last that long, you'd have built enough (about 1.6 million) that you could shut off the oil spigot. Well for today's usage anyway (actually 2006's).
But the first half million you built will be getting might rickety by then...
And that's a technology problem not a political one.
mfb said:50 nuclear power plants built per year.
1 cubic mile of oil (the type is not relevant here) per year corresponds to ~6TW, that is the electricity output of roughly 6000 reactor blocks.
jim hardy said:Furthermore it takes a few thousand plants not fifty.
Authors of that article were trying to show what a momentous project it will be to get us independent of oil in even fifty years -
mfb's 6 terawatts is 6000 gigawatts, and the biggest nuke I know of is about 1.2 gigawatts.
The one I retired from was a dual unit, each ~ 3/4 of a gigawatt.
So it'd be five or six thousand big of nukes, and to build enough of them in fifty years would be one or two per week.
Just like the windmills - you'd have to build a big nuke or two every week for fifty years...
You cannot stop transporting things. If you just replace the power plants, you still burn 80% of the fuel of today (plus something to account for the increasing demand for transportation).mheslep said:The cubic mile of oil (CMO) per year is 1.6*10^20 joules/year, or a bit over 5 TW. Now that's primary energy, about 80% of which goes out the metaphorical tail pipe of the transportation sector it overwhelmingly supplies - more still if the in-the-loop refining overhead is included (10-15%). So the useful power from oil, i.e. that which would be replaced, coming from that CMO/yr is more like 1 TW.
mfb said:You cannot stop transporting things. If you just replace the power plants, you still burn 80% of the fuel of today (plus something to account for the increasing demand for transportation).
I think that is the idea. And you would need a lot of power plants to do so. Sure, batteries plus electric motors are more efficient than current cars (as the power plants are rated by their electric output, as far as I see), but that does not change the main conclusion.mheslep said:Finally, if the argument is to be a theoretical one of counting joules as per the IEEE article , then there's little or nothing physically intrinsic to transportation that can not also be accomplished by, say, nuclear power plants charging batteries or synthesizing methane, etc, etc.
rogerk8 said:My idea was originally to make all those wind-mills that already are placed near the sea to produce hydrogen via electrolysis instead of electrical power (while they are so inefficient anyway).
mfb said:I think that is the idea. And you would need a lot of power plants to do so. Sure, batteries plus electric motors are more efficient than current cars (as the power plants are rated by their electric output, as far as I see), but that does not change the main conclusion.
SteamKing said:The problem with electrolyzing seawater is that you can't just split the water molecules apart. You also split the salts apart (primarily sodium chloride), which makes for some nasty waste products. If you want to avoid this unfortunate outcome, you have to purify the seawater first, which adds a lot of additional energy input into the process.
Integral said:Wind plants require a LOT of concrete, due to this they start with a CO2 deposit that takes years to climb out of.
I missed this earlier. A gasoline tank won't explode? You mean it won't explode from pressure as would a structurally failed 3000 psi tank (with whatever inside)? Yes I recognize gasoline needs to be vapor and mixed w/ O2 to explode (as does H2), but there's no need for movie fiction to demonstrate exploding gasoline tanks.mfb said:The plastic tank is safer than hydrogen under pressure. It won't explode (as we are not in a movie). A burning car is bad, but an exploding car is worse.
http://www.nfpa.org/research/fire-statistics/the-us-fire-problem/highway-vehicle-fires in the US. Used to be half a million decades ago.russ_watters said:Car fires are rare enough - I'm not sure I've ever heard of a car explosion happening in real life.
mheslep said:http://www.nfpa.org/research/fire-statistics/the-us-fire-problem/highway-vehicle-fires in the US. Used to be half a million decades ago.
The only relevant point would be fires that did not involve the fuel tank, regardless of the cause. Other components might burn, but no fuel tank, no gasoline/diesel fire.UltrafastPED said:Keep clicking and you find the breakdown by cause:
No explosion based on what? Sure explosions are over dramatized in movies but that does not mean gasoline vapors in or escaping from a tank can not explode.mfb said:(but still without an exploding tank).
Without knowing how many accidents there are a year, I cat say if that is rare or not, but it is more than I expected. Still, as pointed out, that wasn't the claim you should be sourcing.mheslep said:http://www.nfpa.org/research/fire-statistics/the-us-fire-problem/highway-vehicle-fires in the US. Used to be half a million decades ago.
I don't assert that 100% of a gasoline tank would explode. Heck it is hard enough to achieve perfect combustion in a cylinder designed for combustion. I don't think any flammable will completely explode unless it is somehow premixed with oxygen, and that goes for H2 as well. What I do expect is that whatever small amount gasoline vapor exists above the liquid fuel will ignite and burn rapidly given an opportunity, leading likely to more spillage of liquid fuel which will also burn if more slowly. Does that assumption require a source?mfb said:There is a huge difference between a small amount of fuel leaking somewhere and burning or exploding, and a full tank of gasoline exploding.
It does:mheslep said:Does that assumption require a source?
The results indicate even more: An open tank can continue to burn, but the fire does not get larger.russ_watters said:Mythbusters did an episode on this. Their results indicate explosions are near impossible.
mfb said:It does:
That's a burning car, it is not an explosion.mheslep said:All I'm claiming is that fire damage can occur on the order of the video I provided above, how 'explosive' that may be I have no idea, and doesn't matter much with respect to the assertion that started this discussion, "The plastic tank is safer than hydrogen under pressure. It won't explode (as we are not in a movie). A burning car is bad, but an exploding car is worse." As far as I can tell that statement is dogma.
OmCheeto said:Does anyone know where I can purchase a 1kw hydrogen fuel cell at the DOE price of $47/kw?
The only one I've found online costs $5685!
I have more experiments to do, in the not too distant future.
