What happens if we put a hole in a capillary tube?
Drilling a hole in a capillary tube affects the behavior of the liquid inside, depending on whether the hole is made before or after the liquid rises. The orientation of the tube and the direction of drilling are crucial factors influencing liquid dynamics. A hole's diameter relative to the capillary's diameter can impact the liquid's ability to rise and maintain pressure. Some participants suggest that creating holes could potentially support a higher column of liquid by equalizing pressure from a depression to atmospheric levels. Overall, the discussion emphasizes the interplay between pressure, liquid dynamics, and the structural integrity of the capillary tube.
dark knight13
case 1)The hole is drilled before the liquid rises
case 2) the hole is drilled after the liquid rises
What is the orientation of the capillary tube?
Which direction do you drill the hole?
Compared with the capillary, what is the diameter of the hole?
Do you think a higher column of liquid might be supported if there are holes through the tube because it raises the pressure in the fluid column from a depression to atmospheric pressure?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
