What happens to input power when inverter switched off?
3 replies · 2K views
says
In a PV system, what happens to input power when an inverter is switched off?
I noticed that voltage does not change much but the current does. Does this mean the resistance increases?
define that question clearer ... switched off ... where ?
before or after the input ?
what sort of inverter ?then this Q may be answered better
Dave
After the input power. So the sun is still shining on the PV panel, but the inverter is switched off.
I don't know much about inverters to answer your last question, sorry.
If you disconnect a PV panel from its load, no power is produced. Power P is voltage times current, ##P=VI##. Therefore if ##I=0## then ##P=0##.regardless of ##V##.
If you wish, you can view an ideal switch as a device that changes resistance from ##R=0## when closed to ##R=\##infinity when open.
Does an inverter really disconnect from its source when off? I'm not sure about that.
