What Happens to Liquid Height in Short Capillary Tubes?
  • Thread starter Thread starter geniusprahar_21
    Physics
In short capillary tubes, liquid rises or falls due to adhesive and cohesive forces, with the height determined by the equation h = (2T cosθ) / (ρgR). If the tube is too short (l ≤ h), the liquid does not reach its full height and does not spill over, as adhesive forces are insufficient to pull the liquid further up. The angle of contact remains unchanged in this scenario. When the top of the tube is cut, some liquid will flow out to maintain mechanical equilibrium, resulting in a lower volume of liquid inside while the height of the meniscus stays the same. Understanding these dynamics is crucial for applications involving capillary action.
geniusprahar_21
I don't know if there is a special place for fluids. so i'll post it here...
When a tube of small radius is placed in a liquid, the liquid rises or falls in the tube, due to adhesive and cohesive forces. also the height of the liquid in the tube is given by
h = \frac { 2 T cos\theta}{\rho g R}.
where T is surface tension, \theta is the angle of contact, \rho is the density of the liquid, R is the radius of the capillary tube..
However, if a tube a insufficient length is taken, i.e l <= h then something happens. i am not sure what...but i think, the liquid does NOT spill over, i.e the full height of the liquid is not reached... is it because there is no more adhesive forces to pull ther liquid further up the tube?? in such a case, does the angle of contact remain the same??
is it true?
please explain why, too.
thank you.
Yeah, it's a pity there is no specific place here for fluids but there are places for strings, membranes and so on , even you can check there are several posts about fluids dispersed in PF.
That is a steady solution. If let's say, once reached the dynamical equilibrium you cut the top of the tube such as you cut some portion of the meniscus, some amount of liquid will flow out the tub in order to satisfy the constraint of mechanical equilibrium and the angle of contact \theta. The height of the meniscus would be the same but with some less fluid inside the tube.
thnx, thts just what i needed...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
