What happens when air is heated up?
When air is heated, the molecules do not attain a fixed acceleration or velocity at a specific temperature; instead, they exhibit a range of particle velocities. The mean energy of these particles correlates directly with temperature, reflecting the average kinetic energy. Thermal energy is transferred to the gas through molecular collisions with walls, which affects their energy levels. The concept of acceleration is less relevant in this context, as momentum transfer during collisions is more significant. Understanding these principles can be enhanced by exploring the Kinetic Theory of Gases.
Yong San
Will the air molecules attain a new fixed acceleration at a specific temperature? Or does it attain a new fixed velocity at a specific temperature?
Science news on Phys.org
There will be a huge range of particle velocities at any given temperature. The mean energy of the particles is actually a measure of the temperature. I suggest you google Kinetic theory of gases and then pick a page that suits your level. The "acceleration" of particles is not usually considered as the thermal energy is transferred 'to' a volume of gas by the molecules colliding with the walls and getting their extra energy (or losing it) by interaction with the surface molecules. i.e. we normally think in terms of Momentum Transfer in an unspecified duration of each collision.
But you are right, I suppose, to try to associate increasing molecular speeds with an 'acceleration'. It would be hard to make a model based on this, I think.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
