What Happens When Ba(NO3)2 Reacts with NaOH?
  • Thread starter Thread starter tobyguy
    Formula
The reaction between barium nitrate (Ba(NO3)2) and sodium hydroxide (NaOH) is a double displacement reaction, resulting in the formation of sodium nitrate (NaNO3) and barium hydroxide (Ba(OH)2). The balanced chemical equation is Ba(NO3)2 + 2NaOH → 2NaNO3 + Ba(OH)2. It is noted that barium has a valence of 2, which means two hydroxide ions are needed to form barium hydroxide. A correction was made regarding the initial reaction formula provided, emphasizing the importance of proper balancing. The discussion highlights the significance of understanding valences in chemical reactions.
tobyguy
If you mix BaNO(3)2 + NaOH what would be the chemical chemical reaction in formula?
a simple double displacement reaction
Ba (NO_{3})_{2} + 2Na OH \rightarrow 2NaNO_{3} + Ba (OH)_{2}
balance away!
p.s. dexter is right since Ba has 2 valences there will be 2 OH ions in barium hydroxide
Thanks that really helped. :-p
The reaction provided is incorrect.
Ba\left(NO_{3}\right)_{2}+NaOH\rightarrow NaNO_{3}+Ba(OH)_{2}\downarrow
Do you see the difference?
Daniel.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
