The Time Barrier
During our history there have been many impossibilities and along with those impossibilities came broken records and new limits. First it was to go around the world and prove it wasn’t flat, then it was to fly, then it was to drive a vehicle, control water, make light, control electricity, to communicate with someone on the other side of the world, then to break the sound barrier, then to go into outer space, then to land a man on the moon, and now…now we break the time barrier.
Many scientists have contributed to all of the above accomplishments, each giving a little along the way. But…for each man to contribute his work and get recognized for it, he had to think of the word differently from everyone else. Einstein once said, “The speed of light can never be reached, or even surpassed.” Oh how wrong Einstein was. The entire phrase is a contradiction in itself. If light can reach light speed, then it is a highly possible accomplishment!
Einstein used this formula to base his findings: Time equals time divided by the square root of one minus the velocity squared divided by the speed of light squared, or T=T’/sqrt 1-(V Sq./C Sq). When T=the change in time for the stationary mover, T’=the change in time for the motionary mover, V=velocity, and C=speed of light (186,000 mi./sec.). Now, as long as your velocity never reaches your speed of light, you’re absolutely fine; however, if your velocity reaches or surpasses that speed, well, the speed of light will have to be changed, but since it’s an impossible accomplishment, we won’t go any further…or so said Einstein. You see, 186,000-mi./sec. Divided by 186,000 mi./sec. Equals 1, and 1-1=0. The square root of 0 is a “syntax error” (says my calculator). It cannot be done. Therefore, the speed of light can never be reached.
It is believed (and even proven through mathematical reasoning) that this formula doesn’t work for speeds faster than that of the speed of light or equal to it. Have you ever wondered how fast you’d go in space if you first went 50% the speed of light, then stopped the engines (not the ship, only engines) in mid space and then restarted them at 49% the speed of light? You’d be going 90% the speed of light, right? Wrong, you’d only be going 49% of C (C=the speed of light) because your reference frame had stopped and then continued on 49% of C. In someone else’s reference frame, you are going 99% of C, but in yours you’re only going 49% of C. But if you continually went up to 99% of C in your reference frame, you’d be going precisely that. If you go 100% or above of C, time will no longer exist for you and the formula would no longer work, because you can’t dilate time that doesn’t exist! So there you have it, the time barrier.
