What if gap is irregular in capacitor
  • Thread starter Thread starter Gunmo
    Capacitor Gap
In capacitors with irregular gaps, voltage is derived from the principle that all conductive materials must maintain the same voltage to prevent charge movement. To calculate capacitance, the surface area can be divided into smaller sections, allowing for the summation of individual capacitances. When the distance between capacitor plates changes, work is done due to the attractive forces between opposite charges, resulting in a change in voltage. The relationship between charge, capacitance, and voltage is crucial, as altering capacitance affects the voltage while keeping charge constant. Understanding these concepts is essential for grasping capacitor behavior in various applications.
Gunmo
I don't have clear concept on voltage. I am a Mechanical guy.
If the gap is irregular in large capacitor, how voltage is derived in theory. Using software I can divide the surface into many pieces and calculate voltage of individual small piece.
I attached my problem.
Hi Gunmo,
Yes, this is a kind of 'lots of capacities in parallel'.
For an ideal conductor, all the material is at the same voltage: if not, then the potential difference would let the charge carriers move until the potential (voltage) is equal everywhere.
So, to find capacitance of the device, I need to divide the area with small element and C = C1 + C2 + C3...
The electric field in a capacitor is between its plates.
Since the plates are conductive there can be no field in the direction along their length,
So,
voltage between the plates at any point along their length must be the same, as BvU observed earlier.
But -
That's an interesting example you posed.
Be aware that in deforming the structure work was done while changing the distance between the electrodes.
That's because the opposite charges on the electrodes attract one another.
So when you deformed the plates the Force X Distance product of [ that Coulombic attractive force X distance moved ] has units of work.
That work shows up as a change in voltage across the capacitor.
Charge Q on a capacitor = Capacitance X Voltage
You didn't change Q but you did change Capacitance,
and their ratio is voltage.
Just another little quirk of the universe. Good for "electrical trivial pursuits" parlor games, but don't be surprised if you find it in a physics quiz .
It's good to get your thinking oriented early so that you focus not so much on the plates of a capacitor but on what's in between them.
Watch the electrometer here (about 1:30) indicate increasing voltage as capacitor plates are separated.
Likes dlgoff and BvU
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
