What impulse was delivered to the ball by the player?
  • Thread starter Thread starter missashley
    Ball Impulse
The discussion revolves around calculating the impulse delivered to a soccer ball by a player. The ball, initially moving at 18 m/s to the north, is struck by the player, reversing its direction to 24 m/s south. The impulse is determined by the change in momentum, calculated as the mass of the ball multiplied by the change in velocity. The correct calculation yields an impulse of -19.74 kg*m/s, indicating the direction of the force applied by the player. The final answer reflects the negative sign due to the change in direction of the ball.
missashley
A 0.47 kg soccer ball approaches a player horizontally with a velocity of 18 m/s to the north. The player strikes the ball and causes it to move in the opposite direction with a velocity of 24 m/s.
What impulse was delivered to the ball by the player? Answer in kg*m/s
impulse = change in momentum
momentum = mv
0.47((24-(-18)) = 19.74 kg*m/s
or would it be
0.47(24-18) = 2.82 kg*m/s
i'm lost
The change in momentum will be
mv_1-mv_2 = m(v_1-v_2)
Now keep in mind these are vectors. So one will be a negative number...
.47 kg (18 - (-24) \frac{m}{s})
oops i meant - 2.82, it says it wrong
Nevermind I got it
0.47(-24-18) = -19.74 that's the answer
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
