What is the significance of inverse meters in astronomy calculations?
  • Thread starter Thread starter velvetymoogle
    Inverse Meter
Inverse meters are crucial in astronomy calculations, particularly when using Rydberg's constant, which is expressed in this unit. It signifies a measurement per meter, specifically 1/109737361.6 m. When applying the equation 1/lambda = R (1/nf^2 - 1/ni^2), the constant R should be multiplied by the fraction derived from the energy levels. After this multiplication, the result should be reciprocated to find the wavelength. Understanding inverse meters is essential for accurate wavelength calculations in spectroscopy.
velvetymoogle
Hi,
I'm doing some astronomy work and one problem involves using Rydberg's constant. However, it is inverse meters and I'm confused. Does that mean that it is 1/109737361.6 m? Thanks.
Astronomy news on Phys.org
Yes - it just means per metre.
Okay so if I have the 1/lambda = R (1/nf^2 - 1/ni^2) equation, how would I go about plugging it in? Is it any different than plugging in any other numbers?
after you multiply R by the fraction,
you probably want to reciprocate the result (1/x)
to obtain the wavelength.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
