What am I doing wrong with my multidimensional state array?
  • Thread starter Thread starter Bishop556
The discussion revolves around using a Runge-Kutta numerical method to solve the equations of state for ordinary and neutron stars. The code provided initializes parameters and defines functions for the density and equations of state, but the user encounters issues with the output, which results in a straight line diverging to infinity. The user expresses confusion over the need for three equations to solve for mass, pressure, and density, given that only two equations are currently implemented. A point of contention is the potential misuse of the state array, which is defined as two-dimensional but may be treated as one-dimensional in later calculations. This discrepancy could contribute to the numerical instability and incorrect results observed in the simulation.
Bishop556
Hello, I am trying to now use my Runge Kutta code to numerically solve the equations of state for an ordinary star and then transcribe that to a neutron star. My code is below:
Code:
import numpy as np
import matplotlib.pyplot as plt
from math import pi
#Constants
G = 6.674*1e-11
N = 5000
Gamma = 1.5
K = 5000
dur = 5
dr = dur/float(N-1)
state = np.zeros([N,2])
#initial conditions
state[0,0] = 0
state[0,1] = 5
def rk4(y,r, dr, den, deriv):
    k1 = dr * deriv(y, den, r)
    k2 = dr * deriv(y + 0.5*k1,den, r + 0.5*dr)
    k3 = dr * deriv(y + 0.5*k2,den, r + 0.5*dr)
    k4 = dr * deriv(y + k3, den, r + dr)
    y_next = y + (k1 + 2*(k2+k3)+k4)/6
    return y_next
def density(state):
    return ((1/K)*state[1])**(-Gamma)   # row = (P/K)^(-Gamma)
def EoS(state,den, r):
    y0 = 4*pi*(r**2)*den                         #dM/dr = 4*pi*(r^2)*row
    y1 = (-G*state[1]*den)/(r**2)           #dP/dr  =  -G*M*row / r^2
    return np.array([y0,y1])
r = 1e-23 #starting value to avoid singularity
for i in range(N-1):
    den = density(state[i])
    state[i+1]= rk4(state[i],r,dr,den, EoS)
    r = r + drplt. plot(state[:,1], state[:,0])
plt. show()
What I am trying to do is solve the two equations of state while using the polytropic relation between density and pressure.Now, I am slightly confused on how I can accomplish this as I have three unknowns: mass, pressure, and density which requires three separate equations are needed to develop a unique solution. I, however, am only receiving a straight line that diverges to infinity on the second iteration. Does anyone have any ideas why this is occurring?
Technology news on Phys.org
Also, note that state[0] is mass, state[1] is pressure, and den is density.
I'm not sure about this, but it seems to me that you defined your state array two be two-dimensional (your code: state = np.zeros([N,2]) ), but you are using it later as if it were a one-dimensional array, as in what you wrote above.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
