What is nonlocality in relativity ?
jk22
To explain the correlation in a Bell experiments three solution are considered :
1) faster than light communication
2) preexisting values are revealed at each measurement points
3) nonlocality applies
1) is ruled out by relativity
2) is ruled out by Bell's theoremRemains nonlocality. But what does it mean ?
Is it that in relativity if we go at the speed of light then therr is no space anymore in that reference frame ? Namely if we look at the Lorentz transformation $$x'=\frac {x-vt}{\sqrt {-v^2/c^2}} $$ then v=c is singular.
If we imagine a photon sending a signal from A to B then in its frame all the space between A and B condensate into a single point at infinity since we divide by zero.
This would mean that along A and B in the frame of the phophoton there is no distance hence it were nonlocal and compatible with relativity ?
A photon has no (rest) frame - only massive objects can have one. The signal is sent by massive sources to massive detectors; it only travels (in case of photons) at the speed of light.
This is completely independent of nonlocality issues.
I would not say that faster than light communication is ruled out by relativity.
First, it is possible that relativity, or more precisely Lorentz invariance, is only an emergent approximative symmetry not valid at the fundamental level.
Second, even if it is fundamental, it is not necessarily in contradiction with faster than light communication:
http://lanl.arxiv.org/abs/1006.1986
http://lanl.arxiv.org/abs/1002.3226
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
