What Is the Rise and Span of a Bridge?
  • Thread starter Thread starter avito009
    Rise Terms
Rise refers to the vertical length of a bridge, while span denotes the distance between the two supporting columns. According to Gordon's book "Structures or Why Things Don't Fall Down," the rise should ideally be half the span to maintain structural integrity. The concept of span can be visualized as the horizontal distance, akin to the run in a slope of a line, with rise representing the vertical axis. Understanding these definitions is crucial for grasping the mechanics of bridge design and weight distribution.
avito009
As per me rise is the vertical length of the structure. Am I right? I read in Gordon's book "Structures or why things don't fall down" that the rise should be half the span of the bridge. Why? What does span mean?. As per me span means the area between one end where there is a column and the column at other end.
Think of , Slope of a Line where the Horizontal access is run (span in your bridge),Vertical axis is Rise, and slope is the Delta of change in height over the length of the run.
As a primer for various bridge types, http://www.explainthatstuff.com/bridges.html
As you asked for layman's terms, perhaps discussing fulcrum points as they relate to weight distribution, would be a little premature. :-)
Likes Vedward
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
