What is the acceleration of an object with two given forces acting on it?
The discussion revolves around calculating the acceleration of a 3.00 kg object subjected to two forces: F1 at 60.0 N at a 45-degree angle and F2 at 40.0 N along the +x axis. The calculations yield a vertical force component (Fy) of 42.4 N and a horizontal force component (Fx) of 42.4 N from F1, while F2 contributes 40.0 N horizontally. The resulting acceleration in the y-direction (ay) is calculated to be 34.13 m/s², and in the x-direction (ax) is 13.3 m/s². The total acceleration magnitude is found to be 36.6 m/s², directed at an angle of 68.7 degrees above the +x axis. The user resolves their confusion regarding the calculation of ax, confirming the final results.
mslena79
Only two forces act on an object (mass=3.00kg). F1=60.0N 45.0deg above the +x axis, F2=40.0N on the +x axis. Find the magnitude and direction (relative to the x axis) of the acceleration of the object.
F=ma,
(60.0N)(sin(45))=Fy, Fy=42.4N
(60.0N)(cos(45))=Fx, Fx=42.4N
ay=((60.0N)+(42.4N))/3.00kg
ay=34.13 m/s^2
ax=40.0N/3.00kg
ax=13.3 m/s^2
a=36.6 m/s^2
68.7 deg above +x axis
I can't figure out where I am going wrong.
ax=40.0N/3.00kg
ax=13.3 m/s^2
I think here.
ax is wrong?
nevermind I got it.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
