What is the angular velocity of an aircraft passing overhead at 900 km/h?
haxan7
An aircraft passes directly over you with a speed of 900 km/h at an altitude of 10,000 m. What is the angular velocity of the aircraft (relative to you) when directly overhead? Three minutes later?
Where were studying center of mass and Moment of inertia.
No idea, how to approach this question, Aircraft is flying straight, will there even by any angular velocity?
Draw a straight line from your eye to the aircraft. It changes direction as the aircraft flies over you, does not it? The line encloses an angle alpha with the vertical. Find the expression for this angle in terms of time. The angular velocity is the time derivative of the angle.
ehild
ehild
Speed = 900km/hour
tan(α)=900t/10000
α=arctan(900t/10000)
Derivative is 900/(10000+81 t^2)
If i put t = 0 and t = 3/60, will i get the correct answer? I don't think so, Help me.
Do not mix units. Convert the speed of the aircraft to m/s.
ehild
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
