What is the boundary layer (aerofoils)?
The boundary layer is a thin region adjacent to an aerofoil where fluid velocity transitions from zero at the wall to the free-stream velocity. This phenomenon occurs due to the viscous nature of fluids, which causes them to adhere to surfaces, resulting in a "no slip condition" at the aerofoil's surface. Within the boundary layer, significant velocity gradients exist due to viscous effects between adjacent streamlines. The characteristics of this layer are crucial for understanding fluid dynamics and aerodynamics, as they influence shearing stress and overall flow behavior. For further information, numerous academic papers and resources are available online.
BlueCB
Can someone please explain to me the nature of the boundary layer and its effects on fluid flow over an aerofoil?
Thanks,
When a fluid with nonzero viscosity (essentially any fluid) will tend to "stick to" the wall over which it is passing. This means that at the wall, the velocity is zero relative to the wall. For any fluid moving relative to the wall, there will be some region where the velocity of the fluid transitions smoothly from zero at the wall up to the free-stream value far away from the wall. The region between the wall and the point where the fluid velocity assumes the velocity of the free stream is called the boundary layer.
Likes 1 person
Boudary layer: As the name implies some meaning to this term (i.e)it is a thin layer where velocity gradients exists inside this layer. This velocity gradients exists because of the viscous effects between two adjacent streamlines. At the surface of the airfoil the velocity is zero which is referred to as "No slip condition". Above this boundary layer the velocity will be equal to the freestream velocity...You can find lots of papers and journals regarding BL...Just google it.
Definition from Schlichting's Boundary-Layer Theory:
Boundary Layer: A very thin layer in the immediate neighbourhood of the body in which the velocity gradient normal to the wall, θu/θy, is very large. In this region the very small viscosity, μ, of the fluid exerts and essential influence so far as the shearing stress τ=μ(θu/θy) may assume large values.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
