What Is the Casimir Effect?
  • Thread starter Thread starter Benjamin113
    Casimir effect
The Casimir Effect arises from quantum mechanics, where all of space is filled with waves of various wavelengths. In a confined space between two flat plates, only specific wavelengths can exist, while others are reflected and canceled out. This creates a difference in energy density between the inside and outside of the plates. The resulting force from this energy density difference pulls the plates together. This phenomenon illustrates the impact of quantum fluctuations in seemingly empty space.
Benjamin113
What exactly is the Casimir Effect?
Could somebody explain the basics?
Basically the idea is that all of space is filled with waves of various sorts. (This is a quantum-mechanical thing) Normally, in empty space, there are waves of all different wavelengths, but when you have a small space between two surfaces, only the waves whose wavelengths are factors of the size of the space will exist in that space. Any other waves will be reflected back and forth and cancel each other out. (Example: in a 1cm cavity, you could have waves of 1cm, .5cm, .25cm, etc. but not, say, .7cm)
Now, if you have two flat plates sitting a short distance apart, the waves between them are limited to certain wavelengths. But the waves outside the plates can have any wavelength. So you have a higher energy density on one side of each plate than on the other, and whenever there is a difference of energy densities, you get a force that tries to equalize them. That force is responsible for the Casimir effect.
Cool. Thanks!
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
