What is the coefficient of restitution
The coefficient of restitution (C.O.R.) quantifies the elasticity of collisions, defined as the ratio of relative speeds after and before a collision, ranging from 0 (perfectly inelastic) to 1 (elastic). The formula for C.O.R. is derived from the velocities of two colliding objects, and in cases involving a fixed surface, it simplifies to the ratio of the final and initial velocities of the moving object. In the center-of-mass frame, the relationship between initial and final kinetic energies is expressed as KE_f/KE_i = C.O.R.^2, indicating that kinetic energy is proportional to the square of the velocities. The discussion highlights the utility of C.O.R. in simplifying collision problems, particularly in one-dimensional scenarios, where it can replace more complex energy conservation equations. Understanding the C.O.R. is essential for analyzing the nature of collisions in both theoretical and practical applications.
Definition/Summary
For a collision between two objects, the coefficient of restitution is the ratio of the relative speed after to the relative speed before the collision.
The coefficient of restitution is a number between 0 (perfectly inelastic collision) and 1 (elastic collision) inclusive.
Equations
\textrm{C.O.R.} = <br /> \frac{|\vec{v_{2f}} - \vec{v_{1f}}|}<br /> {|\vec{v_{2i}} - \vec{v_{1i}}|}
where \vec{v_{1i}} and \vec{v_{1f}} are the initial and final velocities, respectively, of object #1. A similar definition holds for the velocities of object #2.
While this is a useful definition for studying collisions of particles in physics, there is an alternative used to define the C.O.R. of everyday objects. In this definition, the velocities are replaced with the components perpendicular to the plane or line of impact. In the case of a 1-d collision, the two definitions are equivalent.
Be sure you know which definition of C.O.R. is the accepted practice in a given situation. For the remainder of this discussion, we use the definition in the equation shown above.
For an object colliding with a fixed object or surface, v_{2i} and v_{2f} are zero, and the C.O.R reduces to:
\textrm{C.O.R.} = \frac{|\vec{v_{1f}}|}{|\vec{v_{1i}}|}
In the center-of-mass reference frame of two objects of mass m_1 and m_2 -- and only in that frame -- the initial and final total kinetic energies are related to the C.O.R. by
\frac{KE_f}{KE_i} = \textrm{C.O.R}^2
where
KE_i \ = \ \frac{1}{2} m_1 v_{1i}^2 \ + \ <br /> \frac{1}{2} m_2 v_{2i}^2
and
KE_f \ = \ \frac{1}{2} m_1 v_{1f}^2 \ + \ <br /> \frac{1}{2} m_2 v_{2f}^2
Extended explanation
Elastic and perfectly inelastic collisions
The coefficient of restitution describes the inelasticity of collisions. If the C.O.R. is 1, the collision is elastic and kinetic energy is conserved. A C.O.R of zero represents a perfectly inelastic collision; after the collision the objects stick together and, in the center-of-mass frame, have zero velocity.
Simplifying 1-d collision problems
In a 1-dimensional elastic collision (C.O.R. = 1), the conservation-of-energy equation may be replaced with
v_{2f} - v_{1f}<br /> = v_{1i} - v_{2i}
In other words, the relative velocity of the two particles has the same magnitude, but is reversed in direction, before and after the collision. By using this equation instead of the conservation-of-energy equation directly, the work of solving a collision problem is simplified as there are no squared velocity terms to deal with.
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
What does coefficient of restitution signify? on what factor does it depends?
The COR represents the elasticity of an impact between two bodies,the impact being either perfectly elastic or inelastic,or somewhere in between.In terms of the numbers simply look at the equation ; its the ratio of the difference of the velocities before and after a collision or impact has happened.In more advanced mechanics classes its use is applied in the energy equations,it comes in handy,when more has more unknowns than equations and wants a closed form solution without complicating one's life with life threatening PDE's.
Hello! Could I please ask why KEf/KEi = COR^2 instead of just COR? Thank you :)
Relative with respect to what in numerator and denominator?
Because KE is mv2/2, which makes the ratio of KE's proportional to the velocities squared.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
