What is the coefficient of static friction for a penny on a rotating wheel?
The discussion focuses on calculating the coefficient of static friction for a penny on a rotating wheel. The penny slides off at a rotational speed of 0.825 revolutions per second, and the user attempts to derive the coefficient using centripetal acceleration formulas. The mistake identified is the failure to incorporate gravitational acceleration (g = 9.8 m/s²) into the calculation. The correct approach involves relating the centripetal force to the normal force to find the coefficient of static friction. The user acknowledges the oversight and seeks clarification on the correct method.
d.tran103
Can someone look at this and tell me what I'm doing wrong? Thanks!
You place a penny on a level rotating wheel at a point 5.00 cm from the center of rotation. You increase the speed of rotation gradually, and once you reach a rotational speed of 0.825 revolutions each second, the penny slides off the wheel. What is the coefficient of static friction
a) 0.718
b) 0.409
c) 0.253
d) 0.137
Fc = mv^2/r = mac
v=wr
Fc = mv^2/r = mac
mv^2/r = mac turns to v^2/r = ac. I converted 0.825 rev/s to rad/s by multiplying by 2pi/1rev to get 5.18 rad/s. I plugged w into v=wr, v=(5.18 rad/s)(.05m) to get v=.259 m/s. I plugged v into v^2/r = ac, .259^2/.05 and got 1.34. However, 1.34 isn't an answer. Can someone tell me what I'm doing wrong?
You found the acceleration. The question isn't asking for the acceleration. It's asking for a coefficient of static friction. That's the ratio between the normal force and the centripetal force. There should be a g=9.8m/sec^2 in there somewhere.
You solved for the centripetal acceleration. Now you need to find and identify the centripetal force.
Thanks, I was missing 1/9.8!
