What is the correct way to wire a piezoelectric circuit on a breadboard?
The discussion revolves around the implementation of a piezoelectric circuit on a breadboard, specifically focusing on activating an LED using a piezoelectric ceramic under pressure. Participants are troubleshooting issues related to circuit connections and component placements.
  • Technical explanation, Debate/contested, Experimental/applied
  • One participant describes their attempt to implement a circuit diagram involving a piezoelectric ceramic and expresses confusion over why the LED remains lit without pressure applied.
  • Another participant suggests that a large resistor (at least 1MΩ) should be connected from the piezoelectric ceramic to V+, referencing a circuit diagram they found.
  • A participant reports that using the suggested 1MΩ resistor did not resolve the issue and asks for clarification on where to connect the power for activation.
  • Another participant indicates that the output pin of the LM108 should be used to drive a power MOSFET if the signal from the transducer is sufficient.
  • One participant points out a potential wiring error, stating that the LED should be connected to pin 3 of the 555 timer instead of pin 5, suggesting there may be additional wiring errors present.
Participants are exploring various wiring configurations and component placements, but there is no consensus on the correct setup or resolution of the issues being faced.
Participants have not fully resolved the assumptions regarding the circuit design and component connections, and there may be dependencies on specific circuit diagrams that are not universally agreed upon.
Individuals interested in piezoelectric circuits, breadboarding techniques, or troubleshooting electronic components may find this discussion relevant.
A31415
Hi, I am having trouble implementing a circuit diagram onto a breadboard. The circuit involves a piezoelectric ceramic, which when pressure is applied, it should create enough power to activate 9V and light up an Led for a second. When I put the circuit together on the breadboard, to the best of my ability, the LED was already lit by the battery and nothing happened when pressure was applied to the piezo. Here is the link for the circuit diagram: http://circuitswiring.com/trigger-555-monostable-circuit-using-the-piezo-transducers/
I have attached the photos of the circuit below. What am I doing wrong?
Thanks!
I cannot see the resistor from the piezoelectric ceramic to V+, but it has to be very large (at least 1MΩ). Here is a circuit diagram I found:
I tried the 1M Ohm resister and the same issue occurred.
For the circuit you suggested. Where would the power, that I am using the piezoelectric to activate, connect?
Thanks!
The output pin (pin 6) of the LM108 has an amplified version of the signal from the transducer. Measure it and if it is large enough, use it to drive a power MOSFET or something.
Did you put it here ?
  • · Replies 36 ·
