What is the current carrying capacity of wire with 1.5mm^2 area?
The discussion centers around determining the current carrying capacity of a 1.5 mm² flexible wire, particularly in the context of practical measurement and the influence of insulation type. Participants explore various factors affecting current capacity, including temperature, insulation material, and environmental conditions.
  • Homework-related
  • Some participants emphasize the importance of specifying conditions such as temperature and insulation thickness when measuring current carrying capacity.
  • Others argue that the current capacity is influenced by the thermal properties of the insulation, with specific mention of PVC and rubber insulation.
  • A participant provides specific data about insulation thickness, ambient temperature, maximum conductor temperature, and thermal resistivity, seeking practical guidance on measuring current capacity.
  • Concerns are raised about the safety of experiments, particularly regarding the melting of insulation and the potential for toxic fumes.
  • Some participants suggest that established tables exist for current carrying capacity based on wire gauge, but caution that these depend on various factors including wire length and acceptable heat thresholds.
  • A later reply questions the relevance of the provided specifications and suggests that the inquiry resembles a homework assignment.
Participants do not reach a consensus on a specific method for measuring current carrying capacity or the comparative merits of different insulation types. Multiple competing views and uncertainties remain regarding the factors influencing current capacity.
Limitations include the lack of specific experimental conditions, potential variations in insulation properties, and the need for safety considerations in practical applications.
This discussion may be useful for individuals interested in electrical engineering, practical applications of wire insulation, or those involved in DIY electrical projects.
jaymin nayak
I have wire of 1.5 mm2(Flexible). Now i want to measure it's current carrying capcity how i can measure it's current carrying capacity?
If you were prepared to operate it at a high temperature then its current would be much more than if you needed to have an undetectable temperature rise. So you would need to specify your conditions.
In practice, the rating is very conservative and will have been reached by experiment and drastically based.
Bottom line is that there is no real answer to this very real problem.
I have to measure current carrying capacity just at room temperature(27'c). I just need simple practical. The wire is PVC insulated.
But it's not simple. Do you want to melt the PVC? How thick is the insulation? What is the thermal conductivity of the PVC sleeving? What temperature do you want to operate at?
All you can do is to calculate the resistance of a length of cable and that will tell you how much power it will dissipate when carrying a given current. That will not tell you anything about it's 'current capacity'.
This is why they publish recommended current ratings - based on experiment and experience. Sums are not enough.
I am not just being difficult. You are not (or, whoever sets the question, is not) specifying what is actually needed to answer the question. Or do you just want to melt the wire? Even that is not straightforward unless the conditions are specified.
I have been given u some data which I have. Thickness of insulation is 0.70 mm. Ambient air temperature is 40'c. Max. conductor temperature is 70'c.Thermal resistivity of PVC is 620'C cm/W. The length of the cable is 1m. & it's max. resistance is 12.1 ohm per km. Sir i have only that data & I have to learn simple practical for measuring current carrying capacity of PVC insulated wire. In above data The ambient temp, The max.conductor temp & Thermal resistivity of PVC are common.if u can't understand please give me more detail about current carrying capacity of cable. Yes i have to melt the pvc. I want to also know which cable has more current carrying capacity PVC insulated or Rubber insulated? Why? Plaese explain it in detail
I really don't want to get involved in this. Use VERY thick wire (1.5mm) and a 2A fuse with a Powerbreaker in the mains socket. That will avoid a lethal shock or a fire. You haven't the manufacturing skills or facilities to go for an economical solution.
Which wire has more current carrying capacity PVC insulated or Rubber Insulated ? Why?
Look over the list of factors. Which ones are relevant? As you haven't committed yourself by giving a full specification them I cannot tell you. This seems too much like a h/w assignment for me to be able to give you more specific advice but I could point out that one type of insulation is much more common.
Moderator's note: the above posts have been moved here from an unrelated thread.
There are several factors that go into this, including:
the ambient temperature
natural vs. forced convection
the thermal resistance and melting point of the insulation
how many wires will there be in the cable?
As a starting point, you could google wire current capacity
I think what this author is asking is relatively simple. How to measure (observe) the current capacity of a wire around 16 AWG gauge with different insulations in ambient conditions.
From what I remember, such an experiment was made in an episode of DIY network's Deconstruction to compare copper wires to aluminum wires. To actually melt the copper wire, (if I remember well) it took quite some current and was provided by a welding power supply. In your case, if you're only melting the insulation, you won't probably need that much current. Remember to perform this experiment in a safe environment, since toxic fumes will most likely be released and there's always a possibility of starting a fire. Also, remember that you are dealing with thermal time constants, so heating the cable with a very fast high-current spike is different than heating the cable with a dc current (or 60 Hz AC).
M.
How long is a piece of string?
There are many tables out there for the current carrying capacity of wire based on its gauge. If its area is 1.5mm^2 that puts it some where in between 15 and 16 gauge wire. Here is an example table.
http://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html
Obviously this depends on how long the wire has to maintain this current, and what the acceptable heat threshold is. For what reason do you need this data? Is this a personal project, or homework?
  • · Replies 19 ·
  • · Replies 29 ·
