What is the current flowing in resistor BC in a complex circuit?
  • Thread starter Thread starter kingstar
    Current Resistor
The discussion revolves around calculating the current flowing through resistor BC in a circuit with three resistors and two batteries. Participants express confusion about the circuit's configuration, particularly regarding the connections at points B and C. Suggestions include using Kirchhoff's laws to set up equations for the two current loops and solving them simultaneously. There is also a consensus that the problem may lack sufficient information for a definitive solution. The conversation emphasizes the importance of accurately interpreting circuit diagrams for effective problem-solving.
kingstar
AB, BC and CD are three resistors connected together at B and C. AB = 12 ohms, BC = 7 ohms, CD = 6 ohms. A battery of emf 48V and internal resistance 0.5 ohms has it positive pole connected to B and its negative connected to D. A battery of emf 74V and internal resistance 1 ohm has its positive pole connected to A and its negative pole connected to C. Find the current flowing in BC.
E = I(R +r)
V = IR
To be honest, I'm clueless.
I tried using E = I(R + r) but unsure how to add up resistors in a triangle :S
I'm not sure of your circuit. Whnat does "connected together at B and C mean?
I am not exactly sure either, I've just copied word for word the question my professor has given.
You should be able to draw the schematic with two current loops. Using Kirchoff's law, you can have two equations with two currents. Solve them simultaneously.
Then tell your professor that he has not provided enough information for there to be a solution.
An interpretation that seems to fit the bill:
I think that there are 3 resistors in series. There are 4 terminals. 12 ohms between a and B, 7 ohms between B and C and 6 ohms between C and D. 48 volt battery with .5 ohm internal resistance connected with + to B and - to D.
Using gneil's diagram I'd just split it into 2 loops and then as 'barryj' suggested, solve them simultaneously.
Will try this and check if its right.
Thanks.
