What is the current in each bulb?
  • Thread starter Thread starter aznseal12
    Bulb Current
Two 40-watt bulbs connected in parallel to a 120-volt circuit each draw a current of 1/3 Amp. The total power for both bulbs is 80 watts, leading to a total current of 2/3 Amp. The calculation of resistance is unnecessary for determining the current through each bulb. The correct approach involves using the power formula P = VI, which simplifies the calculation. Therefore, each bulb operates at 1/3 Amp in this setup.
aznseal12
Two 40-watt bulbs are connected in parallel to a 120-volt circuit. What is the current in each bulb?
Choose one answer.
a. 1/4 A
b. 1/3 A
c. 1/2 A
d. 2 A
e. 3 A
I used V = IR and P = V^2/R
My attempt
40 W = 120V^2 / R giving R = 360
1/R + 1/R = 1/Req => 1/360 + 1/360 = 1/Req => Req = 180ohms
V=IR => 120 = 180I => I = 2/3
which is not an answer
You found the total current (correctly), but the question asks for the current through each bulb.
You don't need to calculate resistance here, assume the total current is I , then I= \frac{80w}{120V}=\frac{2}{3} Amp, the current in each bulb should be \frac{1}{3} Amp
