What is the difference between inductive coupling and magnetic coupling?
The discussion centers on the differences between inductive coupling and magnetic coupling in the context of wireless power transfer. Participants explore the definitions and applications of these concepts, as well as their efficiency and operational mechanisms.
  • Exploratory, Technical explanation, Debate/contested
  • One participant notes that inductive coupling can transfer large amounts of power but has poor efficiency over long distances, suggesting magnetic coupling as a potential solution.
  • Another participant references a Wikipedia definition, proposing that inductive coupling and magnetic coupling are essentially the same, as both involve electromagnetic induction between conductors.
  • A different perspective is offered, where one participant interprets "inductive" as specifically involving coils, while suggesting that magnetic coupling could involve direct interaction between magnets, although this may not be effective over long distances.
  • Another participant introduces the idea that the term "induced" can refer to various forms of voltage induction, including electrostatic, magnetic, thermal, and mechanical, indicating a broader context for understanding these concepts.
Participants express differing views on whether inductive coupling and magnetic coupling are the same, with some suggesting they are synonymous while others propose distinctions based on the context of their application. The discussion remains unresolved regarding the precise differences between the two concepts.
Participants reference definitions and concepts that may depend on specific interpretations or contexts, such as the types of coupling and the conditions under which they operate. There is also a mention of various forms of induced voltage that may not be fully explored in the discussion.
nitzz
Hi
I was learning about wireless power transfer. It is stated that inductive coupling can be use to transfer large amount of power. But efficiency is poor if distance is large. The reccomended solution for this problem is energy transfer through magnetic coupling.
May I know what is the difference between magnetic and inductive coupling?
Thanks. :)
Hello, where did you read this? I was having a hard time trying to think of the difference,
then found this on Wikipedia:
"In electrical engineering, two conductors are referred to as mutual-inductively coupled or magnetically coupled when they are configured such that change in current flow through one wire induces a voltage across the ends of the other wire through electromagnetic induction."
So they are the same thing. As far as I know you cannot induce a voltage if the magnetic field, usually from a coil/antenna, isn't varying. If I HAD to come up with a difference, interpreting "inductive" as using only coils, then two face to face magnets would be magnetically coupled. One would be turned by a motor, while the other (connected to a generator) would follow. I don't see that working at long distances though :).
Thanks for the reply. :)
(Actually i have read it in my lecture note. )
You should note the related term "induced" has a wider meaning.
We talk of
Electrostatically induced voltage
Magnetically induced voltage
Thermally induced voltage
Mechanically induced voltage
  • · Replies 16 ·
  • · Replies 21 ·
