What is the difference between octave and decade in frequency response?
  • Thread starter Thread starter dervast
    Octave
18 replies · 59K views
dervast
Hi i was reading somewhere and i have found the following:
loss:
6db/octave
20db/decade
I know what db is but i don't know what octave is...
Isn't an octave every eight notes on the piano, with each one having half or double the frequency as the one before it?
I'll move this to electrical engineering.
An octave is normally doubling signal intensity, while a decade is multiplying by 10 signal intensity.
I am not sure i really understand what 6db/octave means.. The classic db i have learned it is used for decades.. right?
An octave is a doubling of frequency. A decade is 10x frequency. If you have a single-pole network, the gain through it ratios directly with frequency. So at double or half of some frequency, you get double or half the gain through the network (assuming you are on the rolloff or rollup side of the pole).
To convert from amplitude to dB, use:
A[dB] = 20 log (A/A0) where A0 is some amplitude reference like uV.
To convert from power to dB, use:
P[dB] = 10 log (P/P0) where P0 is some power reference like mW.
So using the first formula for amplitude in dB, you can see that a 10X increase over A0 will give you 20dB, and hence for a single pole rolloff, you will get 20dB per decade of frequency change. For a doubling, you will get 6dB per octave of frequency change.
Note what berkeman has described is consistent with what Mk referred to in music. The 8th note of a major scale is the octave which is 2X the frequency of the starting note. It has the same meaning. The 880Hz A is an octave above 440Hz A and 220Hz A is an octave below.
An illustrative example comparing dB to power; if a transmitting antenna gives you 3dB of gain it translates to 2X (double) the effective radiated power (ERP). If your transmitter outputs 100W, with 3dB gain of the antenna, you effectively transmit 200W. With 9dB antenna, the ERP is (2X)^3 or 800W.
Not really! The gain of a directive antenna is its power output in the direction it radiates relative to the power output of an omnidirectional antenna.
If you have a 100 W transmitter plugged to an omnidirectional antenna, it will radiate 100 W in all directions (a sphere). If you plug it to a 3 dB gain antenna, it will still radiate 100 W, but in an hemisphere. A 9 dB antenna will radiate 100 W in a solid angle of [tex]\frac{2\pi}{8}strd[/tex].
You're correct, directional antennas (e.g. Yagi, Quad, beam etc), have more gain (and ERP) in one direction. It would be clearer to footnote my discussion compared to a unity gain standard antenna such as an omnidirectional. It is also a good approximation for a dipole antenna.
See the table at the bottom of this page for an illustration of gain versus effective radiated power. It is a good rule-of-thumb.
Just try it in the power formula, a variation of the one berkeman gave us.
He had typo, it should be
[tex]dB_{power}=10log[\frac{P_{out}}{P_{in}}][/tex]
applied to erp becomes:
[tex]dB_{power} = 10log[\frac{P_{erp}}{P_{xmtr}}][/tex]
Solving for [itex]P_{erp}[/itex] becomes
[tex]P_{erp}=P_{xmtr}{log^{-1}[0.1(dB_{power})]}[/tex]
Try it, you will see you get a doubling in effective radiated power for each 3dB gain.
dunno why, but even though I'm an EE, i almost never come here.
don't you mean?:
An octave is normally doubling signal frequency, while a decade is multiplying by 10 signal frequency.
rbj said:
don't you mean?: An octave is normally doubling signal frequency, while a decade is multiplying by 10 signal frequency.
Yes, but see post #5 by berkeman.
Regards,
George
Thanks lot reading all the above posts now i know that each octave is 6db larger thatn the previous octave... Still i can't understand that 20db/decade! What that's mean?
No. That is not what we said. The octave itself is not changing. The value of some quantity is changing by some amount with respect to frequency, and that amount can be measured with respect to octave or decade changes in frequency.
Okay, let's try it this way. Do you have some log-log graph paper handy? If not, download some from here:
http://www.csun.edu/~vceed002/ref/measurement/data/graph_paper.html
Now on a piece of log-log graph paper, label the horizontal axis frequency, and the vertical axis impedance. Now I would like you to draw the plot of the |Z(f)| impedance of a capacitor. Let's use some semi-round numbers like a 1uF capacitor and frequencies ranging from 1kHz to 10MHz or so. What are the impedances of the 1uF cap at those two frequency extremes? Using those impedances, figure out how to label the vertical axis of the plot, and draw the plot of the |Z(f)|. Hint -- it will be a straight line on the log-log graph, with a slope of -1.
Now look at that plot and think about what it means. Remember that the impedance of a capacitor goes as 1/2PI*f*C, so it is inversely proportional to frequency, right? That means that a 10x increase in frequency gives you a 10x lower impedance. Recall from the dB equations earlier in the thread that for a non-power measurement you express the change in value in dB by using this:
change [dB] = 20 log (new value / reference value)
A decade is 10x or 1/10x in frequency, so you can say that the impedance of a capacitor changes at +/-20dB per decade. Do you see that now?
Now look again at the graph, and see how many dB the line changes for each doubling or halving of the frequency (that's the octave change in frequency that we talked about). You should get about 6dB (6.021... actually).
Hope that makes better sense now. You will use this concept a lot, so please spend enough time with the log-log plots to get an intuitive feel for how quantities can be expressed this way.
Quiz question -- if you have a 2-pole lowpass filter, at what rate does the transfer function Vo/Vi roll off once you get a decade past the break frequency? How many dB per octave? How many per decade?
Hi folks:
Be careful here. If the original post refers to audio/sound (20Hz to 20kHz), then dB refers to voltage, not power. When referring to sound applications 6dB is half voltage (3dB is half power). dB(voltage) = 20 log (out V/in V). Power depends on load/impedance, which depends on the gear you use (and matching), so sound guys use voltage, not power as their dB reference.
All audio equipment (mixers, sound boards, and most gear except amplifiers) will refer to voltage. The faders on every sound board are calibrated in Voltage (-6dB for half, not 3)
i.e. 6dB atten per octave - 1 octave could be from 2kHz to 4kHz - Voltage down from .7 V to .35 Volts in that octave
20 dB atten per decade- in Voltage/sound, 20dB is an attenuation of 10 (not 100), so a voltage drop from .7 to .07 (not .007).
Hope this helps.
since power is proportional to square of voltage
and a decibel is logarithm;
and, when you square something you double its logarithm
so
20 db of voltage is same as 10 db of power
since the base unit 'bel' is a ratio
it begs the question "ratio to what?"
often electric sound signals are referred to a power of one milliwatt into 600 ohms
which works out to 0.775 volts RMS.
that's because the unit grew out of the telephone industry, hence the name Bel after Alexander Graham.
On better analog multimeters you'll see a db scale.
it's logarithmic with with zero db at that AC voltage.
20dB/Decade means that the signal is increasing 20dB every time the frequency gains an order of magnitude.
For instance if you plot frequency response and the signal gains 20dB from 1Hz to 10Hz then the slope is 20dB/decade.
Hi Jim:
The 0.775V reference actually came from CBS during the early days of television. Yes, 1mW over a 600 ohm load. It is the heart of the old VU (volume units) meter. It is now referred to as the -10dBV relative to 1V as 0dBV (do the math, you get .775V) reference. This is also known as the 0dBu reference level.
Most digital and pro audio systems now use a +4dBu reference which is 1.23V. -10dBV=0dBu, so do the math on +4dB gain with .775V as the 0dB reference (you get 1.23V at output). Your home stereo equipment is all referenced to the -10dBV system (or 0dBu, same thing) level as "0 dB", where as the sound gear, including the mixing board in the studio, or at a concert uses 0dB gain as referenced to +4dBu (or 1.23V). Play pro-audio on your home stereo, and you'll notice how loud it is or blow the speakers. Play a CD player into a pro audio mixer/amp combination and find out how quiet it is - turn up the pre-amp!.
It is amazing, since the units do correlate, and yes power is relative to i squared or V squared.
However, 20dB per decade if your talking power, is 100x, but only 10x if your referring to voltage. Don't draw voltage response on a power logarithmic graph however, or you'll be wrong. That 1/2 "x" (x=power OR voltage) point will be at 6, when it should be at 3.
Whenever I hear 6dB per octave, I'm quite sure you're talking voltage. If I hear 3dB per octave, I'm quite sure your talking power. Typical roll off of common op-amps.
ooops, got that wrong.
-6dB is half voltage and quarter power at the same time. They are all equivalent points on the same log curve. Amazing how hard it is to break a bad habit. Glad I got that mistake out of my head, finally.
Jack
Thanks for that post!
i am interested in audio but have no familiarity with pro-stuff.
does pro video use a higher signal too?
Yes, in most ways. The mixers are the same essentially. There can be more money in video, so the sound component typically uses higher quality gear.
Right now 32 bit 96khz sampling rate is studio quality. CD is 16 bit 44kHz. DVD is 16 bit 48kHz. It's a bit of a trick to "dither" down to the CD or DVD. Live broadcast is lower quality than either of those. Have you ever noticed how bad the broadcast sound is on, let's say, the Grammy awards? Where are the guitars? Most of the bandwidth is reserved for the video portion (a lot more required)
Then listen to the CD they produce - like day and night. The CD tracks were recorded separately probably in a mobile studio something like this one:
http://www.livewireremote.com/frames.asp?l1=thetruck
Doug's 96 channel board is the same one used for Letterman - very high end. Doug's digital upgrade a few years ago cost him $1M. Doug is Canada's #1 live recording guy. The Rolling Stones rider calls for him as the only live recording option when in Canada. He usually does the award shows, and recorded performances for the Vancouver Olympics as well. The AC/DC show on the monitor (web page) was from the concert at Downsview Airport (450,000 people) in Toronto in 2003 that the Stones arranged to promote Toronto after the SARS outbreak - he recorded that too. ProTools is the sequencer software of choice around the world. It is used to mix for the audio tracks on video/movies as well.
