What is the difference quotient of ln (x^3 -5)? Picture provided....
- Thread starter Michael Santos
- Start date
- Tags
- Difference Ln Picture quotient
The discussion revolves around finding the difference quotient of the function ln(x^3 - 5). Participants are exploring the calculus concepts involved in this process, particularly focusing on the definition of derivatives and the application of limits.
- Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
- Participants discuss the use of L'Hopital's Rule versus expanding the expression (x + h)^3 - 5. There are questions about the appropriateness of certain methods and the relevance of specific equations in the context of the problem.
There is ongoing exploration of different approaches to the problem, with some participants suggesting polynomial division and others emphasizing the basic definition of derivatives. Hints have been provided, but no consensus has been reached on a final method.
Participants note the importance of adhering to forum rules regarding homework submissions and the necessity of including relevant equations in the problem description. There is also mention of the need to clarify assumptions and definitions related to the logarithmic function.
- 16,219
- 4,934
Please post in homework and tell us which relevant equations you think you will need to use ...
- 29
- 3
How do i move this over to homeworkBvU said:I wish you wouldn't write ##\ln ## as ##\operatorname {in}##![]()
- 38,131
- 10,706
Do not put the problem details in the thread title. They should go in the problem description of the homework template.
All of the work you show in the image can be done using LaTeX. See our tutorial here -- https://www.physicsforums.com/help/latexhelp/.
For example, $$\lim_{h \to 0} \frac 1 h \ln\left(\frac{(x + h)^3 - 5}{x^3 - 5}\right)$$
Here's what I actually wrote: $$\lim_{h \to 0} \frac 1 h \ln\left(\frac{(x + h)^3 - 5}{x^3 - 5}\right)$$ All of this is described in our tutorial.
To complete the problem, I don't believe expanding the expression ##(x + h)^3 - 5## is any help. A better way to do this is to use L'Hopital's Rule.
Finally, there is no function named "In" -- the first letter is lowercase L, for logarithm.
- 16,221
- 2,889
Considering he's trying to calculate derivatives using the basic definition, I think L'Hopital's Rule isn't fair game.Mark44 said:To complete the problem, I don't believe expanding the expression ##(x+h)^3−5## is any help. A better way to do this is to use L'Hopital's Rule.
After expanding ##(x+h)^3##, you can rewrite the argument of the log in the form (1+something). Go from there.
- 29
- 3
Yes the basic definition is what i am after.vela said:Considering he's trying to calculate derivatives using the basic definition, I think L'Hopital's Rule isn't fair game.
Vela, will you be providing me with the rest of the answer?
- 29
- 3
Vela here is what i have so farMichael Santos said:Yes the basic definition is what i am after.
$$\lim_{h\to 0} {\frac {\ln((x+h)^3 -5) - ln (x^3 - 5)} h} $$
$$\lim_{h\to 0}{\frac {\ln (x^3 +3x^2h +3xh^2 +h^3 -5) -ln (x^3 - 5)} h} $$
$$\lim_{h\to 0}{\frac {\ln (x^3 -5 +3x^2h +3xh^2 +h^3) -ln (x^3-5)} h} $$
I factored and used the product rule
$$\lim_{h\to 0}{{\frac {1} h} ×ln(x^3-5) +ln (1+{\frac {3x^2h+3xh^2+h^3} {x^3-5})} -ln (x^3-5)} $$
I can now eliminate the two $${ln (x^3-5)} $$ terms with subtraction and now i am stuck forever without you aid.
$$\lim_{h\to 0}{{\frac {1} h} ×ln(1+{\frac {3x^2h+3xh^2+h^3} {x^3-5})}}$$
- 29
- 3
Mark44 said:No, that's against forum rules. @vela has given you a strong hint that involves polynomial division.
Mark here is what i have so farMichael Santos said:Yes the basic definition is what i am after.
What now?
- 16,219
- 4,934
- 29
- 3
No i do notBvU said:Do you know a limit for $$\ln (1+\varepsilon)\over \varepsilon $$ when ##\varepsilon\downarrow 0 ## ?
It is approaching one
- 16,219
- 4,934
- 29
- 3
Well i know it now, what can i do with it?BvU said:In that case things become difficult. What equations do you have in your toolkit that may help in this situation ? In the template they are called 'relevant equations'.
- 16,219
- 4,934
I suppose that refers to what you first said you did not knowMichael Santos said:Well i know it now,
? Well, what do you get if you apply your new knowledge to your last expression in post #9 ?Michael Santos said:No i do not
- 10,704
- 1,723
Michael Santos said:Mark here is what i have so far
What now?
You have
$$\frac{1}{h} \ln (1 + \underbrace{\frac{3 x^2 h + 3 x h^2 + h^3}{x^3-5}}_{H} ) $$
Here, ##H \to 0## whenever ##h \to 0##, so you have ##\ln(1+H)## with small ##|H|.##
- 29
- 3
How doez that turn into the final answer ofRay Vickson said:You have
$$\frac {3x^2} { \ x^3-5 \ }$$
- 16,219
- 4,934
You have $$\lim_{h\downarrow 0}\ {\ln (1+h )\over h} = 1$$ so what is $$\lim_{h\downarrow 0} \ {\ln (1+ \left(3x^2 \over x^3-5\right ) h )\over h} \quad \rm ? $$Michael Santos said:Well i know it now,
- 10,704
- 1,723
Michael Santos said:How doez that turn into the final answer of
Plug it in and work it out for yourself. Remember that you want to take the limit as ##h \to 0,## so lots of complicating terms will go away.
- 16,221
- 2,889
- 29
- 3
SoRay Vickson said:Plug it in and work it out for yourself. Remember that you want to take the limit as ##h \to 0,## so lots of complicating terms will go away.
$$ \frac {3x^2h+3xh^2+h^3} { \ x^3-5 \ } $$ = h?
- 29
- 3
-1.39...BvU said:You have $$\lim_{h\downarrow 0}\ {\ln (1+h )\over h} = 1$$ so what is $$\lim_{h\downarrow 0} \ {\ln (1+ \left(3x^2 \over x^3-5\right ) h )\over h} \quad \rm ? $$
- 29
- 3
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
- · Replies 54 ·
- Replies
- 54
- Views
- 20K
- Replies
- 6
- Views
- 2K
- Replies
- 9
- Views
- 3K
- · Replies 8 ·
- Replies
- 8
- Views
- 2K
- · Replies 2 ·
- Replies
- 2
- Views
- 2K
- · Replies 3 ·
- Replies
- 3
- Views
- 3K
- · Replies 5 ·
- Replies
- 5
- Views
- 2K
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
- · Replies 5 ·
- Replies
- 5
- Views
- 2K
