What is the Dimension of a Symmetric Tensor Vector Space?
sgd37
Having a symmetric tensor S^{a_1 ...a_n} forming a vector space V_n with indices taking values from 1 to 3; what is the dimension of such a vector space?
essentially this reduces to picking a tensor of type S^{ \underbrace{1...1}_{s} \underbrace{2...2}_{r} \underbrace{3...3}_{t}} with r+s+t =n and seeing how many non isomorphic combinations there are. I'm not that skilled at combinatorics unfortunately
So... if I'm understanding correctly, this is a slightly roundabout way to ask how many independent components the tensor S has?
Think about it this way: you have a list of n indices which you need to split into a set of 1's, a set of 2's and a set of 3's, in that order. How many places can you choose to put the split between the 1's and the 2's?
Then, given that choice, how many places can you choose to put the split between the 2's and the 3's?
worked it out a different way, thanks all the same
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
