Rupert Young said:
Interesting, this is what I am trying to get to. So what is the source of the lateral force, is it friction due an increase in pressure of the tyres on the ground? Does centrifugal force come into this?
How can we go about quantifying the loss of speed?
I think the problem I have with this is that you are asking for the non-ideal answer, without a real way to quantify. If you yank the wheel hard and start to slide sideways, that is a lot more friction than if you barely nudge it from straight. And really, a constant position of the accelerator (floored, or at a constant gas flow) is not the same as constant force ... there is a power curve for the engine and the change in speed of the car corresponds to a change in rpm of the engine, which means the horsepower of the engine output is different.
If you barely nudge the steering wheel from straight, to a new circular path of a really large radius, you probably won't see any change. If you turn hard, you start to use some of your force for the change in direction, and less for maintaining the speed. You break the force into two components, parallel to the straight ahead direction, and perpendicular to the straight ahead direction. Only the straight ahead component acts on "speed". The perpendicular component acts on direction.
So say you are applying 100 hp, and the speed is constant at 100 mph (that means the total resistance is also exactly 100 hp, or you would go faster). You turn the wheel to 45-degrees. You still apply 100 hp, but it has to be looked at as 70.7 hp forward, and 70.7 hp sideways (Pythagorus again: 70.7^2 + 70.7^2 = 100^2). That means you slow down, as the 100 hp was enough to equal the 100 mph forces of resistance (air resistance, machine friction, etc).
It is not easy to estimate the steady state speed of the car at 70.7 hp. If you measured the straight-line speed vs hp for the car, then you could calculate the speed reduction for any angle of turn. Assuming the angle of turn does not increase machine friction, which seems unlikely as an assumption for any large angles. And again, since the engine rpm changed with the speed, you have to make assumptions about the power output for the constant gas flow.
You are changing directions. That uses force from the engine. That leaves less force for speed. You slow down. How much is going to depend on a lot of things about the individual car.
