What is the effect of multiple forces on a 2D rigid rectangle?
In summary, the rectangle, free to move on a frictionless medium, will experience translational motion as well as rotation around its center of mass when acted upon by a single force at a point. For multiple forces, the translational and rotational motion can be determined by calculating the net force and torque about the center of mass. Additionally, the point of application is irrelevant when determining translational motion.
Droctagonopus
30
Say I have a rectangle of width w and height h centred at (0, 0) on a 2D coordinate plane.
The rectangle is free to move on a frictionless medium. It is not attached at any point.
Case 1: A single force F = (Fx)i + (Fx)j acts at a point (x, y)
How does the rectangle move? I looked it up on some websites and I think that the tangential component of the force rotates the rectangle around it's centre of gravity and the parallel component of the force causes translational motion. Is this correct?
Case 2: Multiple forces F1, F2, ..., Fn act on points (x1, y1), (x2, y2), ..., (x3, y3)
I have searched everywhere for a solution to this problem but I cannot find it. Is there a way to figure out mathematically how the rectangle rotates and/or translates?
Is there a general method to figure out the rotational and translational motion in both cases?
Partly right. The main error is in thinking that only the "parallel" component contributes to translational acceleration. Not so: The entire net force will determine the translational acceleration of the center of mass.
For rotation about the center of mass, consider the torque about that point from each force. Use that to determine the rotational acceleration about the center of mass.
See my comments above.
Yes. See my comments above.
Realize that as the body moves and rotates, the torques and thus the rotational acceleration changes.
But does the rectangle always rotate about its center or mass? Remember, the rectangle is not fixed. It's free to move. It's like a rectangular plate floating freely through 2D space.
I've attached an example. In this case, would the square still rotate around it's centre of gravity because common sense doesn't say so. Although common sense has proven wrong quite a lot of times in Physics.
And also, yes, in the case of a single force, the whole force does contribute but if we were to calculate the acceleration vector of the centre of mass then we would use a = F/m where F is the parallel component of the force, right?
You can always treat the motion of a body as the sum of the translational motion of its center of mass plus its rotation about the center of mass. "Rotating about its center of mass" does not mean that the center of mass remains fixed.
The forces shown in your diagram indicate that there will be rotational acceleration about the center of mass. (We are talking about the instantaneous acceleration at the moment the square and the applied forces are as shown. Things change as time goes on.)
Why do you think it won't rotate about its center of mass?
No.
To find the acceleration of the center of mass you would use the entire force, not just one component.
In your diagram above, what do you think the instantaneous acceleration of the center of mass will be?
Um. I'm unsure. The net force on the object above is zero, right? So there should be no translational acceleration of the centre of mass?
Exactly.
And the total torque of the object is the sum of the torques of each force on the object?
Right.
What if the net force is not zero? Then how can we figure out the translational acceleration of the object? Do we find the net force and its point of application and then find the parallel component of that?
No. You find the net force and divide by mass. Period. The point of application is irrelevant as far as translational motion is concerned. The relevant equation is [itex]\vec F=m\vec a[/itex].
No no. There is both rotational and translational motion. Imagine this square is floating in 2D space with only these forces acting on it. There is both rotational and translational acceleration, right?
Use the full net force and Newton's 2nd law. (Stop with the parallel component already!)
Not given the forces in your diagram. The net force is zero, thus the translational acceleration of the center of mass at that moment is zero.
I don't understand. In the diagram, how is it possible for the square to not rotate? Doesn't the square have both a translational and rotational acceleration?
Who says it doesn't rotate?
No. What's the net force on it, according to your diagram. (You've already answered that. Stick to it.)
Okay. I think I understand the translation. What about the rotation? Does it rotate around the centre of mass? Or another point?
Yes.Pick any fixed point on your rigid body. A corner, the middle of a side, the center of mass. Regardless of your choice, you can *always* describe the motion of a rigid body as a combination of the translation of that selected point and a rotation of the body about that point.
The math is going to be easier with some choices. The center of mass is convenient because its the choice that decouples translational and rotational motion. Another convenient choice is the point about which motion is purely rotational. Things get hairy otherwise. That doesn't mean that its invalid. It just means that describing the motion is more complex.
If we choose any arbitrary point, the net force acts on that point and the moment is around that point. But will the motion be the same regardless of the point chosen?
What about this case? In this case the net force should be directed to the left. But from the diagram it seems like the square has only rotational acceleration.
Yes, the net force is to the left.
Why do you think that?
I'm sorry. I get it now.
To sum up:
To find the instantaneous translational acceleration of the centre of mass of the square I find the net force F and the acceleration a = F/m.
To find the instantaneous angular acceleration around the centre of mass of the square I find the sum of the torques of each force around the centre of mass.
And this method works for any number of forces.
Excellent, except that torque is the equivalent of force. You need to divide torque by the moment of inertia about the center of mass to get angular acceleration.
This approach for rotational behavior only works with 2D objects and simplified 3D problems. The general 3D problem is trickier. For one thing, moment of inertia is now a second order tensor rather than a scalar. For another, Euler's equations come into play. An object with no external torques can undergo angular acceleration. Angular momentum is a conserved quantity. Angular velocity is not.To answer your previous question, "If we choose any arbitrary point, the net force acts on that point and the moment is around that point. But will the motion be the same regardless of the point chosen?" -- That depends on what you mean by the same. Suppose a pure torque (net force = 0) is applied to your rectangle. From a center of mass perspective, the center of mass doesn't move and the object begins rotating about the center of mass. Choose some other point, say a corner. With this selection, the corner is translating and the object is rotating about the corner.
However, suppose at any point in time you plot the position and orientation of the rectangle as a whole (e.g., plot the rectangle's outline). Now both choices will yield the exact same result. If they don't it means a math error was made in least one of the approaches. Choosing a point as the point of interest doesn't change what the object really does. All choice must yield the same result. What that means is that the mathematics can be quite hairy for some choices.
Okay. Thanks a bunch for helping me understand. I'm programming a simulation for a rocket in zero gravity and needed to know an algorithm friendly method of calculating the angular and translational acceleration. Thanks.
I suggest you keep it to a 2D simulation at the start. Three dimensional behavior is a much tougher nut to crack. Getting realistic 3D behavior for a real rocket is a monumental task.
The effect of multiple forces on a 2D rigid rectangle can be described by the principles of Newton's laws of motion. When multiple forces act on a rigid rectangle, the resulting motion can be determined by considering the net force and the distribution of forces on the object.
How do you calculate the net force on a 2D rigid rectangle?
The net force on a 2D rigid rectangle can be calculated by adding all the individual forces acting on the object in both the x and y directions. This will give the overall force vector, which can be used to determine the resulting motion of the rectangle.
What is the difference between balanced and unbalanced forces on a 2D rigid rectangle?
When the net force on a 2D rigid rectangle is zero, the forces are considered balanced and the object will remain at rest or in a constant state of motion. On the other hand, if the net force is not zero, the forces are unbalanced and the object will experience a change in motion.
How does the distribution of forces affect the motion of a 2D rigid rectangle?
The distribution of forces on a 2D rigid rectangle can greatly impact its motion. If the forces are evenly distributed, the object will experience a uniform motion. However, if the forces are unevenly distributed, the object may experience rotation or bending.
What role do friction and air resistance play in the motion of a 2D rigid rectangle?
Friction and air resistance are two important factors that can affect the motion of a 2D rigid rectangle. Friction can cause the object to slow down or change direction, while air resistance can create drag and reduce the speed of the object. Both of these forces can also impact the distribution of forces on the rectangle, affecting its overall motion.
