What is the Effect of Normal Lines on Glass Surfaces?
  • Context: High School
  • Thread starter Thread starter ExperimentingStudent
    Experiment Home
The discussion revolves around an experiment conducted by a student to explore the effect of normal lines on glass surfaces, specifically in relation to the concept of "line of sight." The experiment involves observing how different points on a window correspond to a fixed object outside when viewed perpendicularly.
  • A participant describes an experiment involving pointing at a lamp post through a window from different points, noting that all points appear to point to the same location.
  • Another participant requests clarification on what specific observations or results need explaining, indicating a lack of context.
  • Further clarification is provided regarding the term "line of sight," with the participant reiterating the procedure and observations made during the experiment.
  • A later reply suggests that the normals to the glass are parallel and that the methodology may not be accurate enough to discern differences in the observations made.
Participants express uncertainty regarding the observations and the implications of the experiment. There is no consensus on the interpretation of the results or the accuracy of the methodology used.
The discussion lacks detailed results or conclusions from the initial experiment, and there are unresolved questions about the methodology and its ability to capture the intended effects.
I am a degree student and .. A loner. During my free time, I usually try to observe my surrounding more, you know... :\
Here's the experiment I did (I saved it in my note app, copied it directly from there):
A certain window has a point of view (not referring to the meaning where point of view means opinion)
Just perform these steps:
1. Place your index finger on the window, PERPENDICULAR to the window surface.
2. Then position your head just behind your finger which is perpendicular to the window.
3. Now watch from that view (exactly from the straight view of your index finger)
4. Note (or remember) the place to which your Index finger points to.
5. Repeat the above 4 steps by placing your index finger on different points on the same window.
I would appreciate anyone's explanation based on my (or if you performed this then yours) explanation.
Thank you.
Science news on Phys.org
I think you need to tell us what it is that needs explaining.
We have the method, but not the results nor conclusions. (We'll ignore the object!)
Explanation of what? You haven't told us what you've observed so that we know what to look for.
Sorry, I guess the correct term I should have used was "line of sight". Would have made this a bit more understandable maybe.
Anyway, let me explain this more.
I chose 4 points on any window in my house.
The first image (edit: *re-uploaded* this is last image now, please return to the starting image right after the very last one) indicates the 4 points on the window I chose to perform this small experiment.
The order of following 4 images are:
1,4,3,2.
The digits above is the order of the points I placed my finger on.
Okay now,
Observe the next four images after the very first one (in which the points are indicated).
The only thing you have to look carefully at is the white lamp post position which is almost same for all the four points on the window.
Image '1' :
My finger points to the bottom of the lamp post (quite near to it).
Image '2' :
(Almost similar to the previous image)
Image '3':
Here, my finger points to the top of that lamp post. This spot is quite close to the ones I shown in the previous two images.
Image '4':
Again finger points to the spot nearly close to the ones in images 1 and 2.
Conclusion is all the four points, no matter on which spot on the window I chose them, they all were pointing to the exact one location.
Is this something related to the concept 'line of sight'?
I have already provided the procedure for this experiment for you to test.
Make sure when you are pointing in the perpendicular direction, fix the position of any object you are pointing to or any object which is very very close the spot where your finger is pointing to.
I admit this must be a really different (and sort of weird) topic you all may have never seen on this forum. I wanted some place or someone to tell me answer to my small question (that I have stated above).
I hope I have made myself clear. Please do ask if you want me to show you something more related to this topic.
The normals to the glass are parallel. They point in the same direction, not to same point. Your methodology is not accurate enough to pick up the difference.
  • · Replies 20 ·
9K
  • · Replies 42 ·
  • · Replies 16 ·
  • · Replies 24 ·
