CalcNerd said:
Yes.
While Professor Hubble did find some galaxies were drifting towards us, most were moving away. And the farther these galaxies are from us, the faster they were moving away as determined by their red shift. Hence proof of an expanding universe.
CalcNerd you have confused
expansion and
acceleration.
Hubble's findings, first interpreted by Monseigneur Georges Lemaître, indicated an expanding universe.
This expansion was expected to
decelerate because of the attractive gravitational forces of the matter within the universe in accordance with the cosmological solution of Einstein's GR field equation.
In 1998 two independent projects, the Supernova Cosmology Project and the High-Z Supernova Search Team each used Type Ia supernovae as standard candles and showed these SNe were dimmer than expected at that red shift (z) under the old GR model. This suggested the universe had
accelerated in its expansion rather than decelerated.
Such an acceleration can only be explained by the addition of a Cosmological Constant \Lambda or Dark Energy (DE), in which p = - \rhoc
2 or so.
The density of the DE thus required exactly makes up the density of the universe to its critical value which results in a spatially flat universe. As CMB observations indicate the universe is flat this seems to confirm the observed acceleration and inferred DE. Other observations also indicate the presence of (cold) Dark Matter (DM) in the universe.
These are major components of the standard \LambdaCDM model of cosmology.
However this standard model requires the existence of DE and DM, which have not otherwise been detected in the laboratory, and it also requires the assumption that SNe Ia are standard candles out to cosmological distances.
wolram was asking whether the acceleration could be defined by red shift alone.
wolram, the answer is no - you have to have something else by which to measure the distance of an object observed at a red shift z.
The Perlmutter, Riess and Schmidtet
et al discovery used SNe Ia as standard candles to feed M into the cosmological distance modulus, the result seems to be confirmed by baryon acoustic oscillations (BAO) observations and the DM fits in well with large scale structure formation.
(1 + z) gives you the amount the universe has expanded by since the emission from the object at 'z', and when compared with distance gives the scale factor
There may yet be an Age Problem in the early universe as discussed
here a few times!
To confirm the model further we badly need other distance measures.
(Crossed with
bapowell)
Garth
