What is the force needed to stop an 8,000lb tractor moving at 5mph in one foot?
The discussion focuses on calculating the force required to stop an 8,000 lb tractor moving at 5 mph over a distance of one foot. The kinetic energy formula, K = 1/2 mv², was applied, resulting in a kinetic energy of 6,680 ft-lbs. The force was then calculated using F = K/d, yielding a force of 1,501.7 lbs. However, the introduction of SI units caused confusion, indicating that calculations should remain in imperial units for clarity.
  • Understanding of kinetic energy equations
  • Familiarity with unit conversions between imperial and SI units
  • Basic knowledge of force calculations
  • Experience with physics principles related to motion
  • Review the principles of kinetic energy and its applications in real-world scenarios
  • Study the implications of unit conversions in physics calculations
  • Explore advanced force calculation techniques in mechanical systems
  • Investigate the effects of braking systems on vehicle dynamics
Physics students, mechanical engineers, automotive professionals, and anyone interested in understanding the dynamics of stopping heavy machinery.
Eric Ahlvin
I have a situation where I need to figure how much force it will take to stop an 8,000lb tractormoving at a max speed of 5mph in somewhere around a foot. It will not be an impact stop as there is nothing for it to hit but rather a heavy brake stop. It has been quite some time since I have dealt with kinetic energy equations. Can someone check my work on this?
K=1/2mv^2
m=8,000lb x 0.0310809502 lbs/slug = 248.64slugs
v = 5m/hr x 5280ft/mile x 1hr/60min x 1min/60sec = 7.33 ft/sec
K=0.5 * 248.64slugs * 7.33^2
K= 6,680 ftlbs
where F=K/d and d=1ft
F= 6680Newtons and 1 Newton = 0.224808943 pounds force
so F= 1501.7 lbs
If someone could verify this that would be very much appreciated
Sorry, I see this was not the place to put this, but I also do not see how to delete it...
It makes a great homework problem. Leave it right where it is and don't worry.
Eric Ahlvin said:
K= 6,680 ftlbs
This is good.
This is good.
What are you trying to do dragging in SI units? NOT good.
Eric Ahlvin said:
so F= 1501.7 lbs
The SI conversion messed this up for you. Try it again without worrying about SI.
