What Is the Frequency of the Voltage Source in an LRC Series AC Circuit?
The discussion revolves around calculating the frequency of an AC voltage source in an LRC series circuit consisting of a 1 µF capacitor and a 750-ohm resistor. The voltage source has an amplitude of 4V rms, with measured voltages across the resistor and capacitor being 3V rms and 2.7V rms, respectively. A participant initially miscalculated the current through the resistor as 250 A instead of the correct 4 mA. The correct impedance (Z) can be determined using the formula Z = V/I, leading to a resolution of the frequency calculation. The conversation emphasizes the importance of accurate current calculations in determining the circuit's frequency.
Fisicks
An ac voltage source is connected in series with a 1 uF capacitor and a 750 ohm resistor. The amplitude of the voltage source is measured to be 4V rms while the voltages across the resistor and across the capacitor are 3V rms and 2.7V rms respectively. Determine the frequency of the voltage source.
I said that the current going through the resistor is 250, and then Z=(750^2 + (1/wC)^2)^1/2. So i let 4/250=Z but this isn't right, where am i going wrong?
Thanks guys
This is just an RC circuit (no inductor). Anyway, one the problems I can see with your calculations is that if
VR = IZR = IR,
Then I = VR/R = 3 Vrms / 750 ohm = 4 mArms
not 250 A.
Ok, so I would do 4/(4x10^-3)=Z then?
It should work. Did you try it? Based on your first post, it seems like you know what the correct answer is supposed to be.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
